narrow down drivers for new build
Thread Tools
Old 12th July 2021, 07:50 PM   #1
jimbones is offline jimbones  United States
Default narrow down drivers for new build
Considering a new build. I happen to have a 1.5 cu ft cabinet in my shop not being used so I was thinking either a 2way or 3 way. I have a sub so I donít need subterranean bass.
7 or 8 inch woofer and 1 inch dome
Or
7 or 8 inch woofer, 1 inch dome and Fountek Neo 3 (Hate to use the term super tweeter but this is kind of like Harbeths 3 way with 2 tweeters.)
In a separate thread I was suggested these 2 tweeters
D2604 or DX25BCG60
Woofers under consideration: SS 18W/8531G, Seas W22NY, Seas U22REX, Dayton RS225P-8.
The W22NY is expensive so unless there is a compelling reason to use it. My focus is on clean mids that have a relaxed natural sound. I donít want ultra detail at the expense of musicality. Your thoughts are welcomed and appreciated. Thank you.
Old 13th July 2021, 12:10 AM   #2
system7 is offline system7  United Kingdom
system7's Avatar
8" bass is usually easy enough in a two way:
A U22REX would work well enough I think. Joachim Gerhard likes it with the DXT tweeter on a similar filter:
H1499-06 27TBCD/GB-DXT
Sky's the limit on higher order filters. Restoring Monitor Audio R300 bookshelf speakers.
3 ways are such an open subject, I think you should do some simming. 8" plus 1" plus 3/4" supertweeter is what most people do.
You'd need to work hard at the crossover.
Best Regards from Steve in Portsmouth, UK.
Old 13th July 2021, 04:45 AM   #3
fatmarley is offline fatmarley  England
The Dayton RS225P-8 has very low QMS. Some say that's a bad thing, but I don't know if there's any truth in it or not.
Subjectively, I don't like the sound of metal or plastic drivers, but I haven't heard them all, and we all have different ears, so YMMV.
I quite like the look of the Dayton PS220-8 or the PM220-8. The PS220 needs quite a large ported enclosure, but will work in a relatively small sealed box if you use a good subwoofer to fill in the low end. I haven't modelled the PM220 though. The wonky response above 1.5khz could make crossover design very difficult though...
Although low QMS, I quite like the look of the Seas CA22RNY for a 2-way. I've heard some people say Seas coated paper have a better midrange than Scanspeak, but Scanspeak produce better bass. If the Seas was used in a sealed box with a subwoofer, then the low end wouldn't matter anyway.
The mediaís the most powerful entity on earth. They have the power to make the innocent guilty and to make the guilty innocent, and thatís power. Because they control the minds of the masses. - Malcolm X
Old 13th July 2021, 12:21 PM   #4
system7's Avatar
I was just looking around for a 40L design.
Plenty at Madisound in their crossover archive. But this one caught my eye.
Osprey-BR (Eminence Beta 10CX with Selenium D220Ti) – AmpsLab
If it all fits, Eminence drivers are a very fine lively sound. The 10CX is used in some very high end designs. Not much deep bass, being efficient, but you have a sub I think.
6moons audio reviews: WLM Diva Monitor with Diva Control
Old 13th July 2021, 12:49 PM   #5
Lots to think about here. Let me get back later. I am confused as to why the XO will be difficult if I add a second tweeter.
Old 13th July 2021, 04:55 PM   #6
GM is offline GM  United States
GM's Avatar
Phasing, polar response issues, so my solution way back when was to mount them in a WG to both blend/control dispersion and allow a lower XO point.
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 13th July 2021, 05:29 PM   #7
ugly woofer is offline ugly woofer  United States
If you mount either of your tweeter choices in an 8" wg crossed about 1kHz should mate very well with the scan or seas woofers.
Old 13th July 2021, 05:47 PM   #8
Default new territory
OK so I have never worked with WG's. I wouldnt know what type to use or where to get them or how to model them.....I like the idea, just new to me.
Old 13th July 2021, 05:50 PM   #9
Thinking Seas UX22/REX and DX25BG tweeter (option to add Ribbon at higher frequencies).
Old 13th July 2021, 07:03 PM   #10
Pida is offline Pida  Czech Republic
If you want 8" 2-way, directivity mismatch at Fc and tweeter power handling are the biggest issues.
You have basically two options:
1. You can use large dome tweeter (Bliesma T34A/B, Seas T35, Wavecor TW030WA, ...) and place the crossover <1500Hz.
2. Use waveguided tweeter
Here is what it should look like, as inspiration. WG is WG-300 Monacor. Scan Speak 22W Discovery is probably one of few 8inchers suitable for 2-way speaker and it is budget friendly. It is woofer I would not heasitate to use.
Heissmann Acoustics | Disco-M | 20l reference speaker
Other 8inchers suitable for 2-way:
NE225W
Audax HM210Zx and 210CP
WF223BD
narrow down drivers for new buildHide this!Advertise here!
Thread Tools
Narrow room - need narrow speakers for surround sound duties... Gary Lightfoot Full Range 30 27th October 2014 10:32 PM
Help narrow down these 4 drivers to 1 for me. TY rl guy Full Range 6 29th October 2010 07:45 PM
If I need to low down a +58VDC/1.5A straigth down to 3.3V goldkenn Digital Source 3 20th September 2007 11:56 AM
fullrange drivers and narrow diagram Artmaster Full Range 0 15th December 2005 08:52 AM
help me narrow down the distortion in my marantz 2238B brick Solid State 17 5th November 2005 03:55 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
