The 'Circles of Doom'.....Open baffleless full range speakers.
Thread Tools
Old 25th July 2021, 02:04 PM   #431
CharlieLaub is offline CharlieLaub  United States
Speaking of the "clamshell" (compound dipole), let's compare that to an H-frame using SL's analysis.
SL's model (valid at low frequencies) finds that the output (SPL) for the compound dipole is proportional to two times the effective width of each driver that makes up the compound dipole (usually they are identical). Let's say we use two 15" drivers and they are mounted in 20"x20" baffles. SL's analysis says the output from the compound dipole will be like an H-frame that is 2*20" or 40" long! That is pretty large. But the advantage of the compound dipole is that it will (probably) not have the resonance of an H-frame (because there are no fully enclosed front and rear "tunnels"). This might make it usable to a higher frequency, and based on my quick measurements from a few days ago I would say that is indeed the case.
It would be interesting to compare an equivalent H-frame and compound dipole where D=2*d1 (following SL) via measurements to see the similarities and differences in LF SPL and higher frequency resonances.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 25th July 2021, 04:33 PM   #432
danibosn is offline danibosn  Croatia
design formula is always same, doesn't matter OB, U or H frame. For U and H should be calculated quarter wave resonance and output will be little bit different, as Charlie said, due to air mass load.
I found Kreskowsky papers most thorough analyses of OB. On his pages could be downloaded "A,B,C dipole" spreadsheet.
A, B, C, Dipole
On MJK pages you can find (for small fee) Mathcad spreadsheets for modeling several different box kinds and I found it quite useful for modeling OB's and TL's
Old 26th July 2021, 04:56 AM   #433
David McBean is offline David McBean  Australia
Originally Posted by CharlieLaub View Post
It's not so easy to model it a priori (with the exception of perhaps HornResp)
The Hornresp Loudspeaker Wizard can simulate H and U frame loudspeaker designs in real time using theoretical models developed by 'bolserst'. The model predictions have been validated against measured results.
www.hornresp.net
  Reply to this post
The 'Circles of Doom'.....Open baffleless full range speakers.Hide this!Advertise here!
Thread Tools
full range baffleless speaker dave 111 Full Range 17 6th January 2014 02:58 AM
Video: Our 2011 HomeMade Horn Of Doom Build stimmedmarine Everything Else 0 25th November 2011 01:13 PM
XO protyping box: "The Box of Doom" grantnsw Multi-Way 3 7th April 2010 12:11 AM
Baffleless speakers net-david Multi-Way 3 1st March 2004 07:59 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
