Paul Carmody Carrera build - Completed and audibly Elated!
Thread Tools
Old 11th September 2021, 01:57 AM   #21
prairieboy is offline prairieboy  Canada
prairieboy's Avatar
Originally Posted by schwantzi View Post
Yeah, I actually did use a prestain, which made a big difference but the end result was still a little blotchy. I've also read that using a spray toner can help reduce the blotchy effect although I didn't try it. Maybe next time I'll try the toner fas I really like working with Baltic Birch.
Try shellac, particularly the darker varieties if you want a colour shift. Buy only good quality shellac, and ensure it's fresh. Just don't let your wife put a glass with alcohol on it. :-)
Old 13th September 2021, 10:26 AM   #22
frangus is offline frangus  Australia
Originally Posted by Flaxxer View Post
It is actually simple to get good results with your DIY builds .... you just have to lose the wife! LOL
Or nag her until she accepts the beauty of home brewed craftsmanship
Old 13th September 2021, 10:49 AM   #23
lucadvt is offline lucadvt  Italy
@schwantzi
Can I ask you the dcr of the three inductors?
In the schematic only the inductance is indicated.
Thank you
Luca
Old 15th September 2021, 07:21 AM   #24
zman01 is offline zman01  Bangladesh
The Carrera impedance curve, shows a relatively higher impedance in the 1KHz and beyond region (images attached for reference). The Carrera impedance is around 15 ohms at 20KHz, and the Troels design is possibly around 18 ohms at 20 KHz.
Having a higher impedance throughout most of the mid and upper ranges - would it have any impact on the type of amplifier used?
File Type: jpg Troels - SEAS W15CY001_ HIQUPHON OW1.jpg (94.4 KB, 37 views)
Old 15th September 2021, 02:12 PM   #25
MrHifiTunes is offline MrHifiTunes
You could put a 75uF cap and 5R6 resistor across the connection terminals. It will flatten the impedance and phase curve.
Impedance will be around 4 ohm across the freq range.
I assume tube amps can benefit from it.
  Reply to this post
Paul Carmody Carrera build - Completed and audibly Elated!Hide this!Advertise here!
Thread Tools
FS: Prototype cabinets and crossovers for Paul Carmody "Carrera" and Seas CA15RLY smallangryboy Swap Meet 0 8th February 2021 07:59 AM
Paul Carmody Carrera Build aidenfward Multi-Way 66 16th December 2020 07:26 PM
Paul Carmody Carrera ryanespey Swap Meet 5 19th August 2020 01:33 PM
Carmody Carrera build log 2bz Multi-Way 70 13th December 2017 05:48 AM
New Build: Paul Carmody's Classix II DrDyna Multi-Way 18 27th October 2015 12:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
