Speaker cable connectors: Solder or Screw?
Thread Tools
Old 6th May 2021, 08:57 PM   #11
miglto is offline miglto  United States
I think that's a good choice.
One more question: I am using Cardas solder which is pretty thin so I don't think there's a lot of flux inside. Should I paint a little flux on both surfaces to ensure solder flows well?
Thx.
Old 6th May 2021, 10:02 PM   #12
Galu is offline Galu  Scotland
Sounds OK to me.
Old 6th May 2021, 11:12 PM   #13
Thanks makes sense.
I am using Cardas solder. What do you think of adding just a little bit of flux to the connector and cable surfaces before soldering?
Old 9th May 2021, 01:57 PM   #14
One more question: I have a Weller WES51 solder iron with a screwdriver tip (has a flat surface to transfer more heat to bigger surfaces). This is a 50W iron wand. Is this good enough to solder bananas properly and fully or do I need something more powerful for this job?
Thx
Old 9th May 2021, 03:22 PM   #15
academia50 is offline academia50  Argentina
I see it enough, the power of the welder is important for a good weld, but that is empirical, it depends on the surface to be welded vs. the required temperature, the important thing is to understand the concept of welding. Tin and / or lead easily adheres to hot surfaces, so you should always clean the soldering iron tip before soldering and do not rest the soldering wire directly on the tip of it and then try to make it adhere to the surface cold.
First you heat the surfaces to be joined simultaneously, and rest the solder on it, when you see that it begins to melt, only then can you join the three physical elements. Otherwise it will be a bad, cold junction.
Welding wires usually have fluxes inside, so it won't be necessary to apply external fluxes if you use welding wires of this type. Look for tutorials on YT, there are many on how to get a good weld.
The crimping method is good, and it achieves a good electrical connection, if it is firmly made, no surface rust will form on the joint, which is the only thing that could be counterproductive.
As you can see, I am not an advocate of expensive audiophile cables that promise miraculous results, which does not imply that I would not use them in my audio system if they were given to me, they look pretty !
Old 9th May 2021, 03:28 PM   #16
That said, in the world of "gold ear" audiophiles, the controversy over speaker cables has also moved to wire speaker connections.
The vast majority prefer crimping and avoid soldering.
Old 9th May 2021, 04:10 PM   #17
I believe the Weller WES51 has adjustable temperature, so set it to max.
Provided the wire receptacles in your Z plugs are not heavy gauge metal (which would act like a heatsink), your 50W iron with screwdriver trip should do the job.
Hopefully, you are about to find out that you are worrying unnecessarily, and will soon be reporting back your success!
Old 9th May 2021, 09:09 PM   #18
Galu, what do you advise the OP?
Lead or lead-free solder ?
Old 9th May 2021, 09:13 PM   #19
He is using Cardas solder.
See post #13.
Old 9th May 2021, 09:25 PM   #20
scottjoplin is offline scottjoplin  Wales
Banned
I like Cardas, makes a nice joint.
Speaker cable connectors: Solder or Screw?Hide this!Advertise here!
Thread Tools
Screw type caps vs solder type caps, What's the difference? marchel Parts 8 16th February 2017 01:40 PM
Crimp, solder or screw speaker contacts? jonsson Multi-Way 2 1st January 2017 06:19 PM
How to solder RCA connectors to RG59 cable? BillWojo Construction Tips 9 31st May 2015 06:58 AM
amplifier and screw down terminal connectors? vtgolf Chip Amps 2 17th July 2007 04:40 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
