Hello forum,
I am new to speakerbuilding and would like some advice. I want to build a pair of subwoofers using some fostex L669 woofers.
These are 18" and incredibly heavy, There are two of them in my dads stuff. He says i can have them if i can use them. He doesn't know how long he has had them "a dogs age" mum said.
Thank you ,
John.
Thank you ,
John.
V
Vek
Hi John!
Be prepared to build some big enclosures! I don't know these woofers in special, but in general big membranes force big enclosure volumes...
First it would be good (necessary) for you to know the Thiele-Small-parameters of these speakers. You got any datasheet? Or even better: Any possibility to measure the actual parameters?
Then you would be able to determine the right kind of housing for these woofers: Sealed, vented, ...
There are some nice free softwares around the internet, which will assist you in this task ("Audua Speakerworkshop" and "Liberty Praxis"-demo for measuring, "Linearteam WinISD" for simulating the response in different cabinets, and lots more).
Hope that helps a little bit to get you started
Best regards,
Ralf
Best regards,
Ralf
measuring t/s specs isnt so hard
www.diysubwoofers.org/sbc
id reccomend it,rather than just trying random boxes which may or may not have good result
fostex L669
Thanks for your help guys,
The T/S paramaters are not to be found, at least not by me.
I have done a net search and turned up nothing, fostex don't list it or have specs
These appear to be old, they are quite scuffed and one has a small repair to the cone. If I play them in free air they go quite low, they sound great . They are rated at 8 ohms and 400 watts according to the lable on them.
V
Vek
If you don't want to measure them:
Put each of them in a sealed box of around 100-150 l. You can tune them (at least a little bit) by the amound of damping-stuff you put into the cabinet.
Without knowing the T/S-parameters it is impossible to tell what's the optimal housing for these speakers, but this should work fine. It is much more demanding to find a good vented arrangement by trial and error!
Have fun!
Have fun!
