Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Multi-Way Conventional loudspeakers with crossovers |
Thread Tools |
#21 |
That is it. The resistor 'bends the knee' of the lowpass curve (and reduces the boost just under fc). The higher the value, the more you will end up with a first order crossover (along with the phase shift involved of course). If you're able to measure, try anything between 1 and -say- 4Ω7. If not, start with 2Ω7 and increase if necessary. Calculating with imaginary drivers can be done in Boxsim, Xsim or any other sim app.
#22 |
Thank you all guys, I'll try it and report.
#23 |
You should consider to take out the speaker terminals as it allows you to play freely. A crossover out of the box is already a good thing
there’s no staying at home when you do not have one |
#24 |
Thanks, will do.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Modifying Prebuilt Speaker-Crossover issues | pjpoes | Multi-Way | 2 | 9th April 2007 09:31 PM |
Effects of modifying an existing passive crossover | geolemon | Car Audio | 13 | 15th January 2006 09:06 AM |
Modifying Crossover Advice | BigMacX | Multi-Way | 2 | 6th August 2002 09:49 AM |
New To Site? | Need Help? |
