ARTA and USB interface
Thread Tools
Old 7th April 2021, 10:29 AM   #111
markbakk is offline markbakk  Netherlands
Do you use an XLR-connector on the cable, interface-side, and is the wiring OK? The 2i2 only takes mic input at the XLR sockets, the 6,3mm jack is line level only.
Old 7th April 2021, 11:08 PM   #112
sheeple is offline sheeple
Yes, cabel is XLR-male to XLR-female, the input switch is set at "LINE", should it be "INST" instead?
hallo alamanya—der babo sagt merhaba—her mit dem para ♪
Old 7th April 2021, 11:48 PM   #113
fluid is offline fluid  Australia
ARTA and USB interface-scarlett-png
What the settings like in the Focusrite Control software sometimes things can get weird in there.
Old 8th April 2021, 05:21 AM   #114
I ran a measurement today with my Scarlett 18i20 with the output volume set to give a reading of about 70dB (at 1m) and REW set to output the sweep at -12dBFS, I have the mic gain turned all the way up and get readings of somewhere around -25dB back into REW. It needs to be at this level to leave headroom to record at a louder SPL, with it set like that I can measure up to 95 dB SPL. The levels do not need to be up at -12 to -6dB for REW to measure correctly. You will get a warning if the recording level is too low.
Old 8th April 2021, 08:20 AM   #115
Reading it again it makes sense. Acoustic noisefloor under normal conditions will be around 30-40dB (flat). So the mic inputs don't have to be much more sensitive and with recording you'll need headroom up til 110dB or more. Measuring at 60dB isn't the best either, it only leaves you about 20-30dB S/N ratio, so measuring distortion or acoustic slopes becomes unreliable. Speakers should easily do 90dB on 1m. So turn up the volume.
  Reply to this post
ARTA and USB interfaceHide this!Advertise here!
Thread Tools
Interface / Soundcard for ARTA DR ANALOGUE Equipment & Tools 0 13th October 2019 12:53 PM
Issues using E-MU 0404 USB for measurements (ARTA and RMAA) maxw Equipment & Tools 102 23rd September 2018 05:17 PM
RMAA / ARTA interface for measurements (looking for EMU alternatives) df audio Equipment & Tools 28 9th January 2015 12:10 PM
Little USB/Digital interface box with I2S interface QA01 lxiaob Digital Source 0 2nd January 2013 04:51 AM
ARTA - using ARTA to measure room acoustics! OMF Software Tools 0 25th November 2009 01:55 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
