What Happened To My Tweeters??
Thread Tools
Old 25th January 2021, 11:12 PM   #1
aslepekis is offline aslepekis  United States
Default What Happened To My Tweeters??
This is a new one for me.
I'm designing a set of speaker using a Beston RT002A (the non-dipole version), I built the cabinets, measured the raw response of the drivers in the cabinets, then went to designing the crossover and painting the cabinets. I did a test fit/listen tonight and something didn't sound right, nor did they measure right. There's a ~5dB depression centered at 4kHz that's now there even if the crossover isn't connected, and it's present in both tweeters.
Anyone have any thoughts on what may be going on here?
Old 26th January 2021, 12:08 AM   #2
mainframe99 is offline mainframe99  New Zealand
Impedance measurements?
Old 26th January 2021, 12:38 AM   #3
Not much difference there to speak of, they are just about on top of each other.
To add another observation, I'm noticing that after painting the cabinet, the recess for the tweeters isn't as deep as it was before painting (paint build up on a rough surface), and the tweeters themselves are about 1/8" less recessed than they were before painting.
Old 26th January 2021, 03:05 AM   #4
5th element is online now 5th element  United Kingdom
5th element's Avatar
A difference of 1/8" of an inch isn't going to cause that much of a difference with regards to diffraction. These tweeters are horn loaded too so that should reduce diffraction effects even more.
I have no idea what's wrong with them.
The impedance plot might not be much diagnostic use with a tweeter like this though as they are basically a flat line.
The low end roll off of the tweeter is essentially identical to before implying that the sealed cavity behind the tweeters isn't amiss. Also the overall sensitivity is the same and as the roll off is the same that implies the overall basic function of the tweeter hasn't been affected.
What happens if you go off axis? I would be surprised if diffraction is causing this but something has to be. Try putting felt around the tweeter or make a quick and dirty test baffle out of cardboard or something where they are perfectly recessed. Heck add in a layer of cardboard to the front of the speakers to bring the tweeters flush with the baffle once more.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 26th January 2021, 04:05 AM   #5
bansuri is offline bansuri  Italy
I would say there is an air leak ribbon/waveguide. The plastic bends when you force the mounting screws. Try some silicone sealing.
It maybe also the ribbon is damaged from blowing at it or operating them without xover
Old 26th January 2021, 11:18 PM   #6
Here's 0 to 90 degrees off axis. I tried acoustic foam on the baffle too, but it didn't do much of anything to speak of.
Both tweeters I have are showing the dip, and I did a full half-hemisphere of measurements on both of them without a crossover in addition to other general tests a month or two ago before the dip showed up yesterday, so I'm hoping that they haven't been damaged from my earlier measurements.
Appreciate all the ideas so far! Nothing like a puzzle that makes no sense...
Old 27th January 2021, 01:38 AM   #7
adason is offline adason  United States
adason's Avatar
Did you cap protect them during full frequency sweep?
Could be some damage from measurement.
I suggest you use them from 6kHz up to salvage the problem.
Old 27th January 2021, 10:11 PM   #8
I only ever did a sweep up from 1kHz up on them, but no, no blocking cap for the measurements. Measurement levels were always kept low, so I would have thought that damage would start showing up on sweep 2 rather than suddenly on sweep 40 with the crossover in place... although I did connect one node of the crossover incorrectly, so it's not like I'm above user erroring.
I forgot to mention in my last post that the two images are the before and after of one of the two tweeters in question.
Old 27th January 2021, 11:30 PM   #9
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
Questions-
This is in the speaker will full xover, right?
Are your coils in the woofer and tweeter networks close?
Are the coils placed/installed at orthogonal right angles?
Are you using litz-coils on your tweeters?
If they are not placed this way or are very close, options:
Separate the coils.
Flip a coil over.
Reposition them.
If you used litzes on your tweeters, swap to standard air-core.
I think your issue either lies in the capacitive nature of the litz coils causing the blemish, or that of coils coupling and causing a response aberration.
I've seen this before.
Later,
Wolf
Old 28th January 2021, 07:50 AM   #10
markbakk is offline markbakk  Netherlands
The dip is present without Xover.
Check the foils thoroughly. Any conductive tracks looking wrinkled? You might have to open the units. Check your amp for DC output. Such ribbons are more prone to overload than regular domes. The conductors become too hot and the glue binding them to the foil releases.
I've been there (more than 30 years ago...) when I smoked Multicel 'supertweeters'. A few years later a house party destroyed my Technics TH400s. Both of the pairs did produce sound after the incidents, but not up to specs.
What Happened To My Tweeters??Hide this!Advertise here!
Thread Tools
udial and 4 destroyed tweeters later, what happened? (take #2) simon5 Digital Source 5 11th November 2005 06:48 AM
udial and 4 destroyed tweeters later, what happened? simon5 Multi-Way 20 1st November 2005 04:39 AM
What Happened jleaman Everything Else 5 21st July 2002 01:53 AM
What ever happened to Class-B? JoeBob Solid State 16 13th April 2002 01:39 AM
Whatever happened to N.E.W.? Michael Rothacher Solid State 0 25th August 2001 10:11 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
