New guy need some help with old speakers
Thread Tools
Old 21st January 2021, 04:30 PM   #12
Tgf05354 is offline Tgf05354  United States
Here is a crude drawing of my crossovers from what I can see. If you can give any feedback or comments etc Iím all ears. Remember Iíve been out of the game for a long time and have forgotten a lot.
The Low Pass looks like a positive lead to a .85 air core leading to two parallel 10uf capacitors to a 2.49 resister then negative
The High Pass looks like positive to two parallel capacitors (2uf and 4.7uf) then a .47 air core to negative and a 3.01ohm resistor to tweeter positive lead then a 10ohm resistor back to negative.
crossover.pdf - Google Drive
Low pass components are
.85 mh air core
10uf capacitors (2)
2.49 ohm resistor
High pass components
.47mh air core
4.7uf capacitor
2uf capacitor
3.01 ohm resistor
10 ohm resistor
Old 21st January 2021, 04:54 PM   #13
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Hi, I would replace the two caps in line with the tweeter with one 6.8 uF/250V film cap, only if they are effectively in parallel ( if it was C-L-C, i.e. a 3rd order crossover, and not a C-L...).
Also the woofer cap...22uF ( standard, but you may find 20 uF) single capacitor is better than two. In this case you don't need a film cap. I mean, you can go Polypropilene if you don't mind spending 10/20 $ for a cap. 6.8 uF/250 V goes at about 2/3 $ ( phisical store, no boutique brand)
thereís no staying at home when you do not have one
Old 21st January 2021, 05:06 PM   #14
Thanks, can you tell me what the crossover frequency point is and what slope? I'm going to try and post some actual pictures of the crossovers.
Old 21st January 2021, 05:19 PM   #15
Ooooh it should be around 2k5 Hz as usual
Really, IDK!
The slopes....slooooopes....the resistor on the leg of the 20 uF cap suggests a mild action of the cap itself, which means lesser attenuation...err...not so steep as there was no R. It goes together with the damping wanted for the speaker+box, so you might want to change its value ( hint: don't do it!)
Old 21st January 2021, 05:19 PM   #16
Not sure if this helps or not
Old 21st January 2021, 06:06 PM   #17
system7 is offline system7  United Kingdom
system7's Avatar
I can't see anything there, my friend. You need to upload images to the forum with the paperclip thing in the reply box.
Here's what your circuit should be. 2kHz crossover, 4dB less bass below 500Hz than Lynn's circuit which is 3kHz crossover. But it works well enough, IMO. If you are happy with the bass, I would leave well alone.
Best Regards from Steve in Portsmouth, UK.
Old 21st January 2021, 06:26 PM   #18
crossover.pdf
[ATTACH]0001.jpg[/ATTACH]
Am I wrong in thinking leave well enough alone?
Old 21st January 2021, 06:45 PM   #19
system7's Avatar
Your diagram is wrong!
The 10 ohm is across the red and white tweeter wires, No?
Good components. Functional wiring. Looks OK.
Old 21st January 2021, 07:03 PM   #20
Yes, you are correct, my schematic is wrong. It took me a bit to wrap my head around the wiring, put the second 10ohm resister crosses the tweeter + and - . Learning a lot here, very grateful. Looks like I will leave it alone although I may rewire the speakers to the crossover boards to make it neater. New voice coils due next week.
New guy need some help with old speakersHide this!Advertise here!
Thread Tools
Speaker guy vs Amplifier guy gainphile Multi-Way 108 15th November 2010 03:00 AM
Some electronics toys to young and old guy's fun! destroyer X Solid State 5 10th May 2005 11:12 AM
Will some one help the new guy with his Sansui SP-5500X's? ancorp Multi-Way 9 15th July 2004 03:34 AM
Help a new guy out with some weird 3 way passive x overs meltmanbob Multi-Way 3 29th March 2003 10:07 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
