Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Multi-Way Conventional loudspeakers with crossovers |
Thread Tools |
Hi!
I'd like to build some 3 way open baffle using Beyma 12P80ND v2 as a mid and Faital Pro 10AK compression driver for the high frequency. For the low frequency I will decide later the driver(s). Do you think it can be a good choice? Any particular horn in mind? I am looking at Faital Pro LTH 102, looks OK. Any ideas for a good passive crossover is highly-appreciated. Thank you! |
#2 |
It's gonna be hard to make a 3way open baffle unless you implement some substantial modifications regarding 10AK ;-)
Anyway, I enjoy those compression drivers for a while now. They are attached to the LTH102, crossing them at 1000Hz. Faitals 12PR300 play below... I think Beymas are gonna be OK as well or even better, lots of happy people using them. Good luck!
Who hath ears to hear let him hear. |
#3 |
One more thing: 10AK is not that flat as you can see on the faital pro website. Some work is needed there, still tuning mine :-)
#4 | |
What kind of substantial modifications regarding 10AK do you have in mind? Maybe another horn? Do you use Faital Pro 12PR300 in open baffle? Thank you! |
#5 |
You just can't have a compression driver open... So it's gonna be a mids/bass open baffle with "closed" highs...
12PR300: I have them open now, had them closed for a while and going to try them aperiodic... sort of... I think that the latter will be the final solution.
#6 |
I'm learning about dipoles as well. I've been evolving my design which also started with a closed-back tweeter - a Beyma TPL-150H AMT in my case. I learned at this forum that a good starting point is to have dipole back wave up to about 6kHz for back wall reflections. That is why some designs include a back firing dome tweeter.
I did open the back of my tweeters, in fact later added a proof of concept back waveguide and have kept it. Of course this is not possible with a compression driver. FWIW, I don't remember seeing the 12P80ND on open baffles. Try searching within the Ultimate OB thread. cheers! |
#7 | |
I saw this approach on PAP Trio15 Horn1. |
#8 | |
#9 | |
What are the estimated crossover points for the 12" as midrange? Do you have measurement capabilities and any measurements you can share? |
#10 |
diyAudio Moderator Emeritus
Why do you think this is not possible with compression drivers to remove the back?
Attachment 914341Attachment 914342
http://basaudio.wordpress.com |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Crossover Info request for a Passive OB with Beyma CP21F, Beyma TPL150H, 12P80ND | JohnnoG | Full Range | 2 | 1st December 2019 03:38 PM |
Faital Pro 12PR300 or Beyma 12P80ND/V2 at 120 Hz+? | Doppler9000 | Multi-Way | 7 | 13th September 2017 06:13 AM |
Seeking SEOS 12 and Beyma 12P80Nd V1 FRD files | frangus | Multi-Way | 0 | 2nd August 2016 03:37 AM |
Two-way - JBL 2226H + CD or Beyma 12p80nd + TPL-150? | Rullknufs | Multi-Way | 34 | 17th December 2014 01:49 AM |
The Traps, a ML-TQW experiment with Beyma TPL-150 and 12P80nd | Cort | Multi-Way | 41 | 4th June 2014 01:30 PM |
New To Site? | Need Help? |
