Are Hammond reactor good for woofer crossover?
Thread Tools
Old 21st January 2021, 08:36 AM   #21
ygg-it is offline ygg-it  Italy
ygg-it's Avatar
That is interesting. But what about in AC, with a variable audio current signal ?
What would be the inductance and will it be constant?
And why a normal ferrite line inductor should behave differently from a transformer EI coil?
I ask because I need to understand how simulate the first-order cutoff frequency with that -6dB slope.
I just found a local manufacturer which can build a transformer coil for me, like the hammond one.
Old 21st January 2021, 10:25 AM   #22
ticknpop is offline ticknpop  Canada
Actually for 30 mh thats a low DC resistance. No difference between reactor, choke, and inductor - different names for the same part. You’ll never get an air core at that value (big as a house with a much higher DCR and what would it cost). I used big 20 amp 10mh Hammonds on passive Dynaudio subs and they were very good (big and expensive too).
Then I moved to powered JL audio F212 , those were even better, but cost a lot, lot more.
Old 21st January 2021, 10:41 AM   #23
ygg-it's Avatar
Thanks, so you probably used 195J20
Question is now: if your inductor is rated 10mH at 20A DC, how much inductance was in your crossover circuit, where there is no DC?
10% or 20% more?
Old 21st January 2021, 11:56 AM   #24
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Originally Posted by ygg-it View Post
Which is the difference between this reactor and an inductor?
Absolutely zero, no difference, except in name.
Anyone that says otherwise, has no idea, what an inductive reactor is used for!
It is just a laminated core Inductor.
Old 21st January 2021, 12:50 PM   #25
markbakk is offline markbakk  Netherlands
As the permeability of the core material will decrease when the core goes into saturation, the effective inductance will go down with rising (DC) current. But I think the specified DC value and the specified inductance on the coil will stand, e.g. as long as the current doesn’t exceed the specification, the inductance will be more or less stable. I don’t really see why DC and AC would give different outcome.
Another thing is that such a reactor might be more prone to microphony because it isn’t as tightly wound as you would like for audio applications. It has been mentioned in an earlier post in the thread. But there you’d have to eat the pudding.
Old 22nd January 2021, 04:37 AM   #26
ygg-it's Avatar
Originally Posted by ErikdeBest View Post
Another thing. The specification of 30mH is with the 5A DC current. Besides tolerances that may change this value, if there is no DC current the actual inductance will probably be higher.
Here, maybe, a clarification from Murata Power Solution inductors:
"The maximum DC current is defined as the DC current at which the inductance falls to 90% of its nominal value ....
When making comparison with Inductors, it is worth noting that many manufacturers quote a 30% drop which gives the impression of a higher current rating"
inductors - Murata Power Solutions
Here a definition of "saturation current"
"Saturation current is defined as the DC bias current that causes a specific amount of inductance decrease, usually 10%, 20% or 30% inductance"
How to Understand Power Inductors Parameters for DC/DC Converters | SOS electronic
According to that (10-30% drop in DC) and considering +/-15% tolerance it seems that if I need a 30mH working in AC only (40WRMS@8ohm = 3A peak < 5A ), I should purchase an inductor 10-15% less, that means 195G25 Hammond Manufacturing or order a 25-27mH 5A DC max transformer coil.
Would this be wise?
Old 22nd January 2021, 07:28 AM   #27
Would you notice the difference? I mean, what brought you to the conclusion that you needed 30mH? I really don't think anyone will be able to discern the two in blind tests.
Old 29th January 2021, 05:33 AM   #28
ygg-it's Avatar
Got at excellent price (with shipment fm US to Italy free!) two monsters 30mH 8A 300milliohm inductors (EI laminated core plus air gap as in the photo) from Signal transformer.
3.6 Kg each!
Measure 30mH with 10% tolerance with two different LCR meters.
As a first test fantastic to cut everything at -6dB first order slope.
Just tried in serie with my loudspeakers, cut everything from 100Hz.
Attached the new design.
File Type: jpg The 53rd Anniversary Tower Speaker (under design) with filter.jpg (304.6 KB, 16 views)
Old 29th January 2021, 11:21 AM   #29
Wow, those are ugly... good work, have fun with them!
  Reply to this post
Are Hammond reactor good for woofer crossover?Hide this!Advertise here!
Thread Tools
FS: Anode reactor - plate choke (filter choke) DIYspaceW Swap Meet 6 25th December 2019 03:38 PM
FS: Reactor / choke 1H at 1A DIYspaceW Swap Meet 17 3rd February 2015 12:23 PM
FS: Electra Print Plate reactor DIYspaceW Swap Meet 6 6th February 2014 09:33 PM
FS: TRIAD C-30X FILTER REACTOR DIYspaceW Swap Meet 2 2nd November 2013 01:58 PM
Extreme DIY: Building a homemade nuclear reactor in NYC makingmoney Power Supplies 4 26th July 2010 09:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
