Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Multi-Way Conventional loudspeakers with crossovers |
Thread Tools |
#11 | |
The voice coil of the titanium tweeter is damped and cooled by 'ferrofluid' whch can dry up over time. This may explain the "harshness" you think you can hear in the speakers. Old ferrofluid may be removed and new ferrofluid installed in order to bring the sound of the tweeters back to spec. I'm not sure from your posts if you are intent on renovating these speakers or simply wishing to discuss how good (or bad) they are. If you do not require any more renovation advice, I'll bail out now. EDIT: I see Ugg10 got in in front of me regarding the lower driver! Last edited by Galu; 13th January 2021 at 03:07 PM. |
#12 |
Like the idea of replacing the fluid if it's practical to do so. I don't fancy drilling out spot-welds or anything like that... but if it's simply a case of popping out a couple of screws then I may be up for that.
#13 |
Not really worth taking that tweeter apart. A modern $20 tweeter can match or exceed its performance. All depends how involved you want to get.
At a minimum I would: -Change out the caps to new ones. -Install a new tweeter and place some felt or other absorbing material around it. This would make for a noticeable improvement. |
#14 |
Here is how ferrofluid is replaced: Replace ferrofluid in tweeter - a B&W tweeter as an example
#15 | |
#16 |
Production quality/consistency and design. Less distortion, better matched frequency response.
Even foam around your current tweeters can smooth out the sound. Especially at higher spl's. |
#17 |
what about changing away from metal tweeters... good or bad idea?
#18 |
Depends on the tweeter in question. I like metal domes but I've only tried expensive ones. There's a lot to like about modern soft domes. Exceptional performance to price. Either can give great results.
When/if you take the tweeters out, measure the frame dimensions, the cutout, and check the impedance. Might even be marked. |
#19 |
This 8 ohm, 90dB, 96mm square frame, titanium dome tweeter could be a direct replacement: Visaton DSM 25 FFL Size 96 x 96mm
#20 |
Attached images show the original MS titanium tweeters for comparison.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
is there any any good Mp3-Player?? | ViennaTom | PC Based | 182 | 28th September 2019 10:41 PM |
any good walking shops in the uk for good capacitors | youngie | DIY HiFi Supply | 0 | 12th February 2013 11:08 PM |
Pulling any voicing from any good drivers | river251 | Multi-Way | 10 | 29th May 2012 07:11 AM |
Looking for a good DIY PCB kit - RS ones any good? Others? | Morse | Chip Amps | 33 | 5th March 2009 03:38 PM |
Any suggestions for a good solution at a good price? | supertronik | Everything Else | 0 | 18th December 2005 02:40 PM |
New To Site? | Need Help? |
