Accelerometers to measure panel vibrations?
Thread Tools
Old Today, 03:31 PM   #361
Remlab is online now Remlab  United States
This is the full fr of the piezo accelerometer on the dunlavy side panel. The 60hz mains AC line interference is terrible, but as far as normal, braced cabinet resonances are concerned, totally irrelevant, and can be windowed out, so for all intents and purposes, measurements from 70 hz and up are unaffected by any noise that's left in the system, and can be counted on as reliable.
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old Today, 03:45 PM   #362
Pano is online now Pano  United States
Pano's Avatar
Thanks! What are we seeing on the lower, jagged plots? Is that the same thing with different smoothing? Or harmonics? Although the noise is mostly a good way down, I wonder if those spikes at 540, 660 and 880 are contributing to your cabinet measurement? That said, the spike at 300 does not seem to be contributing.
It will be interesting to see what your shielding does. Will you have to shield both sides?
Take the Speaker Voltage Test!
Old Today, 03:47 PM   #363
Dunlavy panel resonance vs "acoustic null technique" panel resonance. The reason I'm spending time on this is for measurement verification. I'm pretty satisfied with the results I'm getting.
  Reply to this post
Accelerometers to measure panel vibrations?Hide this!Advertise here!
Thread Tools
Want to get Accelerometers/Vibration Sensors sdep777 Equipment & Tools 2 20th July 2018 07:39 AM
Moving Magnet Sub with accelerometers and DSP eriksquires Multi-Way 0 27th May 2018 03:57 PM
Do you measure then listen or listen then measure? midrange Multi-Way 34 5th October 2017 11:45 PM
Accelerometer to measure the loudspekaer's box vibrations diypass Multi-Way 15 24th February 2017 02:15 PM
Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? percy Multi-Way 0 12th March 2006 10:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
