Best compound to dampen enclosure?
Thread Tools
Old 21st October 2020, 01:02 PM   #21
cracked case is offline cracked case  England
Originally Posted by 3wayaddict View Post
Well CLD with a box within the box is quite difficult and uses a lot of volume. An idea I have. Instead of the butyl damping, stick some very heavy plates to the walls with a very soft foam inbetween. Seems to me like this should dampen the walls very wel. Kind of the same as CLD. Except it's not a sealed box in side a box. PMC did the same with the outer panels on their flagship Fenestria speaker.
Decoupling the driver could also work very well though I'm afraid of doing it in practice on my speakers. I can imagine mounting the midrange on a soft damping material could compromise it's transient response. Also, such a system would have to be tuned very well to make it work in your favor and not against you. I can imagine that such a system could also make the midrange lose transient impact/attack and make it sloppy. So I'm kind of scared to put this in my own speakers where I only have one shot at it.
IMG_20200825_185116.jpg A box in a box is quite doable, with soft foam between the internal box ( or boxes ) and outer box.
The truth has a quiet voice, and I feel alone in having the ears to listen.
Old 21st October 2020, 01:42 PM   #22
bansuri is offline bansuri  Italy
I use Hawaphone for vibration Hawaphone, the sound insulation from Korff AG
and Twaron Angel Hair for volume damping 10-20g/liter https://www.eltim.eu/en/damping-material-etc/mundorf-angel-hair/g-10000062
Both are expensive but unsurpassed
Old 21st October 2020, 02:13 PM   #23
phase_accurate is offline phase_accurate
If someone wants to use Hawaphon(e) make sure that you get it from a supplier for carpentry and not a DIY speaker supplier. There can be quite a difference in pricing !
Charles
Old 21st October 2020, 02:50 PM   #24
Remlab is online now Remlab  United States
Laurence Dickie also completely decouples his drivers in his designs using a tensioning rod on the back of the drivers and rubber gaskets. I imagine that extremely thin sorbothane would not effect the transient response in a bad way and more than likely would improve it.
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old 21st October 2020, 03:21 PM   #25
On my traffic light speakers I bolted the three front ( there's also on in the rear) drivers directly to the front baffle, however there are two square steel bars going from top to bottom on each side of the drivers ( for both weight and stiffness ) and the front baffle is held on by three tension springs against a cork gasket, which is also between the steel bars and front baffle for a damping effect. The stands are hollow to increase the volume.
Old 21st October 2020, 03:28 PM   #26
HiVi Kevlar? i imagine cork would work well as a decoupler. Where are you low passing them at?
Old 21st October 2020, 03:44 PM   #27
Some cheap Aiyima drivers from Amazon, glass fibre I think. The unconventional crossover is work in progress; I'm tempted to have some out of phase treble coming out the rear, and increasing the bass. I originally ran them all full range as a mini line array, but not for long...
Old 23rd November 2020, 11:12 AM   #28
Sorry for the delay in response, the above image is the " crossover ", I think that the 1.9 mh choke has too much resistance because they sound a bit soft, unfortunately because the speaker is crammed full of drivers it would be impossible to have an iron core away from the magnets, I may have to have a choke in the stand. All four drivers are the same, with 6 ohm dc impedance, if I remember correctly. The values were just tuned by ear.
Last edited by cracked case; 23rd November 2020 at 11:13 AM. Reason: spelling ( dyslexic )
Old 23rd November 2020, 11:31 AM   #29
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Some may disagree but those bags of sand atop the cabinet do work. Pretty easy to diy
Old 23rd November 2020, 11:48 AM   #30
amplidude is offline amplidude  Denmark
In my build I poured 10mm of levelling concrete on all inner surfaces, instead of adding pure water I mixed a third of wood glue and glass fibres, really sturdy, cabinets are dead silent,
Added weight is 25 kilo
Best compound to dampen enclosure?Hide this!Advertise here!
Thread Tools
Do you dampen a Uframe? mrkennyk Multi-Way 12 28th July 2015 06:21 PM
Dampen transformer endbells? pjanda1 Tubes / Valves 13 22nd January 2013 09:25 AM
Do lighter cones of a given size dampen and settle quicker? asberrys Multi-Way 19 13th July 2012 05:05 PM
Is it possible to dampen a partially microphonic 12ax7? DrStrangelove Tubes / Valves 8 5th May 2011 01:19 AM
Dampen metal cone resonance: How much is enough? gary f Multi-Way 33 14th February 2009 05:53 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
