Help expert woodworkers
Thread Tools
Old 18th October 2020, 02:37 AM   #11
Joel Wesseling is offline Joel Wesseling  Canada
Joel Wesseling's Avatar
If veneer is well adhered, a router and spiral down cut bit will produce perfect results, with no tear out.
RFTD1600 - Whiteside Machine Company
Old 18th October 2020, 02:56 AM   #12
solarfish is offline solarfish  Canada
Originally Posted by AllenB View Post
I would not use power tools on veneer.
A laminate trimmer is a small router specifically used for thin laminates which are very similar to veneer. There is nothing wrong with using a router on veneer so long as you take small cuts to avoid splintering, possibly even using a climb cut (anti-clockwise if cutting a driver recess). That being said, I missed the point about the OP question, what should be used in that instance is a rebating/rabbeting bit.
update: I should mention I used exactly that bit to slightly enlarge the recess for speaker build yesterday.
Old 18th October 2020, 03:16 AM   #13
AllenB is offline AllenB  Canada
AllenB's Avatar
Ok, I'll grant you that but as someone who is learning, OP should not be encouraged to think that power tools are necessary or superior. You learn the craft with no electricity, except for the lights. You can achieve the finest work by hand.
Old 18th October 2020, 03:41 AM   #14
Certainly true, but even with decades of experience I wouldn't claim to be able to cut a perfect circle with hand tools, something that is trivially easy with a router and jig.
Old 18th October 2020, 03:43 AM   #15
AllenB's Avatar
Right, but with decades of experience I'd expect that you know that's not what I'm talking about
Old 18th October 2020, 04:06 AM   #16
Cal Weldon is offline Cal Weldon  Australia
Speakerholic
Cal Weldon's Avatar
When the good members are saying X-acto knives, do they really mean box cutters?
That's all we use anymore.
Old 18th October 2020, 04:06 PM   #17
puppet is offline puppet  United States
I've seen this several times and still wonder why people rebate a driver prior to veneering. Rebates should be the last step.
The veneer is adhered properly and chance of tear out is zero.
Old 18th October 2020, 04:42 PM   #18
hifijim is offline hifijim  United States
hifijim's Avatar
Allen is right. If you have a circular cut-out with a circular rebate to flush mount the driver, and you have veneered the surface, you can use a sharp knife (X-acto or utility knife use a fresh blade) to follow the rebate edge and trim the veneer. I would rough cut it with a scissors first.
A small router or laminate trimmer works well also. This is what I use.
Old 18th October 2020, 04:46 PM   #19
prairieboy is offline prairieboy  Canada
prairieboy's Avatar
Second that!
Old 18th October 2020, 05:32 PM   #20
hifijim's Avatar
For me, cutting the rebate is the second step in cutting a hole.
1) First I drill the 1/8 inch hole for the circle jig pin. This is a full depth hole. My baffles are usually 2 layers of 3/4 inch stock.
2) I cut the rebate (flange recess) so that the depth is equal to the driver flange thickness and the diameter is the driver diameter + 1mm or + 1/16 inch. I use a 3/4 diameter rabbeting bit in a small router. I use a Jasper circle jig.
3) Using a 1/4 inch spiral up-cut bit, I cut the hole. I make multiple cuts, each about 1/4 to 3/8 inch deep. Halfway through I flip the panel over and cut from the other side.
4) After the circle is cut out, I use a 60 degree chamfer bit with a roller bearing to chamfer the back side. My bit is a top-mounted bearing, so this has to be done from the back side of the panel.
Since I need access to the back side of the baffle, all my circle cutting operations have to be done before the panel is assembled to the box.
I prefer to veneer the finished box, so for me, the veneer gets applied over a fully machined driver hole. A laminate trim bit works great for trimming out the veneer, but a sharp X-acto knife would work.
Help expert woodworkersHide this!Advertise here!
Thread Tools
BALTIC BIRCH Plywood - PRO TIPS for WOODWORKERS mp9 Construction Tips 1 15th August 2020 03:15 AM
LCD expert kzeprf22 Parts 6 8th September 2011 11:50 PM
Little help from the expert please.... Mikka Solid State 14 7th June 2003 04:23 AM
Little help from the expert please.... Mikka Parts 1 6th June 2003 06:50 AM
Little help from the expert please.... Mikka Everything Else 0 4th June 2003 10:36 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
