Ports for Bandpass Enclosure
Old 16th October 2020, 02:11 PM   #11
markbakk is offline markbakk  Netherlands
With bandpass enclosures it could pay to flare the port. Depends upon the application (with subs it is more likely) but chuffing can be more easily detected because the woofer output itself will be absent.
Old 17th October 2020, 02:37 PM   #12
presscot is offline presscot  Thailand
Is the port diameter important? I have planned to build my speaker with triangular ports. Yet, the port area is limited by the cabinet dimension. My friend, who is professional in building car subwoofer, said it isn’t important. Many of his designs had the port diameter or port area for non-circular ports fixed because of the beauty. And he often played with the port length instead. He suggested that the port size be concern for only not to generate turbulence, it is simply keep it as big as possible or at least big enough. This is the only main concern. Is his statement true? Also, what will happen if the port size is too big?
Old 17th October 2020, 10:57 PM   #13
AllenB is offline AllenB  Australia
AllenB's Avatar
If you go making it too wide, it gets rather long as well. Apart from where to put it, it will also begin to look like a transmission line that favours the midrange. That could be a problem on its own.
  Reply to this post
Ports for Bandpass EnclosureHide this!Advertise here!
6th order bandpass ports proximity valtra103 Car Audio 4 2nd September 2016 02:47 PM
Bandpass Enclosure goodguys Multi-Way 14 13th May 2015 05:04 AM
Why bandpass enclosure? Aleksrussian Subwoofers 37 19th July 2013 11:02 PM
help with a bandpass enclosure idahoxj Car Audio 4 5th July 2005 08:56 AM
enclosure configuration via ports ChesterFuzzin' Multi-Way 3 17th December 2003 08:34 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
