Active LR4 crossover phase matching using a DSP
Thread Tools
Old 25th October 2020, 12:34 AM   #221
fluid is offline fluid  Australia
Originally Posted by URI55 View Post
REW is wrong on this.
To display phase one needs to set a reference point in time.
What RWE is doing :
It takes the IR of the Low Pass and finds the peak, uses this as reference to plot the phase of the LP.
Then it uses the peak of the HP┤s IR ( which is different ) to plot that phase.
To compare two phase traces, one always needs the same reference time ( delay ).
Why is this easy to spot:
In simulated HP/LP there is no time of flight involved, therefore the phase trace should always be going down ( except for REW )
The phase plot of REW for the LP generates negative Group delay, which is second best to time travel
Thanks for pointing that out you are of course right and REW just plotted what I told it to I swapped the low pass and high pass around for it to give a positive delay number rather than request time travel.
I took a shortcut and didn't estimate the IR delay I just made REW find the match point for me.
This is the impulse difference
Active LR4 crossover phase matching using a DSP-delay-estimated-jpg
Then in the alignment tool no delay is necessary, sorry if I confused anyone. The relative differences still apply just not the specific delay numbers. This is another example of why time locked measurements are necessary.
Old 25th October 2020, 05:11 AM   #222
Ro808 is offline Ro808  Netherlands
Originally Posted by bolserst View Post
...you might find the following paper of interest:
"Power Response of Loudspeakers with Noncoincident Drivers -- The Influence of Crossover Design,"
J. Vanderkooy & S.P. Lipshitz, J. Audio Eng. Soc., Vol. 34, No. 4, pp. 236-244 (Apr. 1986)
AES E-Library >> Power Response of Loudspeakers with Noncoincident Drivers-The Influence of Crossover Design
Old 25th October 2020, 11:33 AM   #223
Viper_user is offline Viper_user  Sweden
Viper_user's Avatar
Originally Posted by fluid View Post
That can be the case and is shown graphically here, but if you have a straight polar lobe then tilt the baffle the lobe will tilt with it too
Interresting! So in other words, For best results: Active xover for driver aligned and FIR is needed for group delay systems?
Old 25th October 2020, 11:53 AM   #224
I'm not sure how the quote and the comment come together but group delay can be altered or removed with an FIR filter of the right type but that is not a free lunch either though.
Old 25th October 2020, 12:47 PM   #225
Viper_user's Avatar
Well, "Physical aligned" in your picture have no electrical phase shift electronics but good lob.
Old 25th October 2020, 04:09 PM   #226
mark100 is online now mark100  United States
Thx Ro808,
I read it, then reread the link ernperkins gave in #208, trying to get a better handle on power response and lobing.
Must admit, the more i read papers like these, the more I get convinced that steep linear phase xovers are the way to go. I wish someone would put a similar paper out on them for a reality check.
Old 25th October 2020, 04:25 PM   #227
Originally Posted by tmuikku View Post
And if one wants to control directivity to further manage the off axis response a waveguide is needed. Multiple entry horn is pretty much the only thing that can achieve the goal of 1/4wl spacing and controlled directivity. A true point source
I think so too....there just doesn't appear to be another way to get to 1/4wl spacing, with directivity.
Other than electrostats i guess,
or maybe line or ring arrays using a boatload of various sized drivers.
Synergies sure look like the best alternative to me...getting ready to post another one.
Old 25th October 2020, 06:58 PM   #228
johanhaggstrom is offline johanhaggstrom  Sweden
They can be tilted back up but it is just another thing to consider as to which is the best compromise for the application
Thank you fluid for the good illustration. This illustrates was exactly what I was trying to describe.
Im my case, I can only do the Phase-shift in steps of ~11us or ~3.66mm, which means that I end up in a combination of the first and second picture.
In order to correct this I tilt the baffle, which corresponds to the third picture, which takes me to a combination of second and third picture in order to make the lobe horizontal.
An extra challenge is that I have two crossovers to align (W-M, and M-T), which makes the tilting a bit more tricky, since both are affected at the same time.
As bentoronto points out it can be discussed how accurate/puristic you need to be when aligning the phases/timing.
In my experience it pays off to spend some time on this, and the reward is a more relaxed sound, but must of course be balanced towards all other imperfections.
  Reply to this post
Active LR4 crossover phase matching using a DSPHide this!Advertise here!
Thread Tools
Active - How to Simulate Phase Matching eriksquires Multi-Way 11 14th November 2016 05:51 AM
active 3way crossover phase ioannidis Multi-Way 42 17th March 2016 08:25 PM
matching speakers with an active crossover newbie06 Digital Source 9 7th October 2006 12:03 PM
Active crossover with linear phase response ackcheng Solid State 1 20th July 2004 06:54 AM
? Active crossover with constant phase ? promitheus Solid State 11 4th July 2001 04:05 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
