Fostex FT17H - hurts my ears
Old 23rd February 2019, 11:44 PM   #31
audiomovil is offline audiomovil
Originally Posted by Rewind View Post
It is a gamble but I would go for these, as long as your current driver can do midrange. Fountek NeoCd3.5H Horn Tweeter
Excellent for my budget and needs, thanks!
Old 23rd February 2019, 11:56 PM   #32
Rewind is offline Rewind  Sweden
Rewind's Avatar
I can't promise that it will sound good, and with ribbon tweeters you can usually not cross as low as with dome tweeters. Safe bet qould be 3000Hz, maybe 2300Hz. It loos more sensitive than your Fostex cone driver, so maybe add a resistor or biamp. Consider that some ribbon tweeters already have a coil in the form of a transformer My Raal has 2mH in its transformer, so I need to think about that when making the crossover. If I add a coil, I can't just think about that coil. I wou°d make the passive crossiver as low and as simple as possible and then experiment with a digital filter like minidsp to find the sweetspot, and then look at the B4 active analog filter when it comes out eventually.
Old 23rd February 2019, 11:59 PM   #33
Originally Posted by adason View Post
That is an excellent inexpensive ribbon. Great suggestion. I have used it two builds.
Great!, any advice about the xover?
I'm using Fostex FF225WK in a MLTL
Old 24th February 2019, 01:45 AM   #34
adason is offline adason  United States
adason's Avatar
Sorry, I took my pages down, was likely 7kHz.
Audio Pages
Old 24th February 2019, 10:58 PM   #35
Rewind's Avatar
Audio Pages
That was high. I bet he could cross it lower as well.
Old 25th February 2019, 01:34 PM   #36
Audio Pages
Don't worry, thanks!
Old 25th February 2019, 01:35 PM   #37
I will try different capacitor values, I will go lower to see what happens.
Old 25th February 2019, 02:14 PM   #38
badman is offline badman  United States
badman's Avatar
There's a lot of good advice here, a steeper slope would go a long way, and it likely wants more padding, and the midwoof should have some shaping. The midwoof may be part of what's bothering your ears, high-bandwidth minimal XO drivers with whizzers can shred your ears, and moreso at higher level.
I get the appeal of a minimalist widerange/supertweeter setup, but the more experienced I've become the more I appreciate a well designed multiway system with good XOs. In this case, a proper horn/waveguide would be a much better solution. You can use something like the "Econowave" project as a start point.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 26th February 2019, 02:18 AM   #39
Thanks Badman, I didn't know those "Econowave", interesting!
Old 26th February 2019, 10:58 AM   #40
krivium is offline krivium  France
Hi if you decide to go 'econowave style' check Pi Speakers offer.
W. Payrham offer interesting things for diyers.
Fostex FT17H - hurts my earsHide this!Advertise here!
Where to find Fostex FT17H in or near the UK? bigwill Multi-Way 12 14th June 2008 06:00 PM
JVC Car Stereo, Intelligent EQ, Hurts Ears voicetek Car Audio 0 15th July 2007 08:02 PM
FS: Fostex FT17H Illusus Swap Meet 2 6th March 2005 10:46 PM
Fostex FT17H with Audax PR170M0 - will this work? Saurav Multi-Way 22 14th April 2004 09:56 PM
New Project Beta 12LTA Fostex FT17H in a TQWT MIKET Multi-Way 27 23rd March 2004 04:14 PM
Copyright ©1999-2019 diyAudio
