Recommendation for a good mid range driver for vocal
Old 16th September 2020, 03:48 AM   #31
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by JamesTan View Post
@Pano - It is great to hear you have good experience with the Morel midrange domes, any model in particular?
Originally Posted by GM View Post
Which one[s] in particular?
Errr.... now you're asking the tough questions. It's been a few year and I'm sure I used to know, but would have to do some research now.
Take the Speaker Voltage Test!
Old 16th September 2020, 07:50 AM   #32
markbakk is offline markbakk  Netherlands
OK, I'll try to make my point better. This is a Zaph Audio ZA14 as measured by John Krutke on a IEC baffle:
Recommendation for a good mid range driver for vocal-schermafbeelding-2020-09-16-om-09-30-55-png
This, again, is the driver mounted in a normal rectangular box:
Recommendation for a good mid range driver for vocal-za14w08-ingebouwd-response-120706-jpg
As you see, rather disturbing differences mainly in the lower region. This is due to the baffle step function. As the differences exceed 5dB, they certainly are noticeable. I hope you see you need measurements of the driver in YOUR box.
File Type: png Schermafbeelding 2020-09-16 om 09.30.55.png (248.4 KB, 140 views)
Old 16th September 2020, 09:33 AM   #33
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
My vote would be for Monacor MSH 115 4 inch midrange.
Good efficiency, smooth response all the way out to 10kHz, and great value.
We don't rise to the level of our expectations, we fall to the level of our training
Archilochus
Old 16th September 2020, 10:06 AM   #34
JamesTan is offline JamesTan
Hi guys, kindly help me out and do a little survey here. If today you are going to build or buy a new pair of speaker, based on the 3 attached FR curves, which one would be your favorite? The one on the left as 1, center as 2 and right as 3. TIA .
Old 16th September 2020, 10:34 AM   #35
Wow... that's a nasty difference with and without the box. Thanks for sharing that and now I see why many of you keep advising me to get a measuring mic to do a proper measurement.
Old 16th September 2020, 10:46 AM   #36
rstillin is offline rstillin  United States
Are there not accurate tools to simulate the nicely traced curves on large baffles to ones in small box baffles? Try the "response modeler" to simulate the baffle induced changes and model from there. I also see higher crossover points on the tweeter in most applications. Closer to 3k 4th order.
Old 16th September 2020, 11:18 AM   #37
AllenB is offline AllenB  Australia
AllenB's Avatar
They are fairly similar.
Old 16th September 2020, 11:21 AM   #38
Which one would you choose?
Your eyes make the choice easy!
But then again....its only a sim, and baffle effects will render any decision made based on those plots, moot.
Archilochus
  Reply to this post
Recommendation for a good mid range driver for vocalHide this!Advertise here!
Driver recommendation needed - self-contained tweeters & mid-range toffee123 Multi-Way 3 5th June 2017 05:52 PM
Driver for vocal Viper_user Multi-Way 27 30th January 2016 02:23 PM
Good vocal recordings phishead8 Music 68 7th February 2014 10:46 PM
HLLY T-Amp 90 good on violin and vocal?? fatboysan Vendor's Bazaar 0 22nd February 2011 05:16 PM
Good vocal A'af Music 0 20th January 2002 02:29 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
