RST28F and DC130A Foamcore Homage to LS3/5A
Thread Tools
Old 29th November 2020, 06:15 AM   #171
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
They can get pretty satisfyingly loud. I place them above my 10F/RS225 TLs which sound big, and these sound surprisingly similar in scale and voicing. They lack the bass of course.
At 84dB 1m and 2.83v that’s 1w, if we go to 64w that’s 6 doublings at 3dB each or 18dB more. 84dB + 18dB = 102dB max.
They really are meant for small rooms or near field monitors - similar to the intent of the LS3/5A. For desktop computer or mixing monitors, they sound great. Very neutral and balanced voice and tone.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 30th November 2020, 07:00 AM   #172
tubemax is offline tubemax  Netherlands
Hi xrk,
Great looking enclosures! I would agree with you that they are best for small rooms/nearfield use, in my case they also want big power amp with big reserve of power...
I end up buying Crown XLi800 for them, just great transparent sound form this entry-level crown... I would never imagine that PA Amp can compete with audio grade gear but you never know until you try it for yourself!
Old 30th November 2020, 07:42 AM   #173
wilbur-x is offline wilbur-x  Norway
XRK, do you plan for a 3-way, the "Foamage" with the 8" Dayton TL ?
Old 5th December 2020, 04:19 AM   #174
Got Foam?
xrk971's Avatar
You mean add a tweeter to the 10F/RS225 TL? No, not a proper 3-way. I have played with adding a dome super tweeter aimed straight up at the ceiling with a 0.47uF cap for ambiance. It was interesting but in the end I went back to a 2-way FAST.
In the meantime, I have been listening to the Rockvilles as near field monitors and they sound fantastic. There is really a lot more bass when they are 2.5ft away from your head. Sometimes they sound clear like good headphones. I have them sitting on EVA foam blocks (yoga stretching blocks) that make excellent monitor stand isolators.
I have powered them with 100w Class AB, 39w Class A, and an IcePower 1200AS2 (new toy I am testing out for a client) and it all sounds great. Of course never taking up to the full power of these amps - typically play around 8w to 15w and that is plenty loud.
RST28F and DC130A Foamcore Homage to LS3/5A-rockville-nearfield-jpg
Old 13th December 2020, 12:33 AM   #175
Got Foam?
xrk971's Avatar
Still listening to the Rockville’s and having built 3 sets now, have verified that the choice of drivers and crossovers is solid. The voicing and balance comes out spot on each time. They really do sound exceptional as near field monitors. I compare the sound balance to my open back headphones and putting headphones on or taking them off - sounds about the same. Very nice.
File Type: jpeg 5FF6F965-BC2E-46C3-9B0F-257E4A2A7833.jpeg (576.9 KB, 143 views)
Old 14th December 2020, 04:50 AM   #176
yatr98 is offline yatr98  Canada
Hello X,
I was wondering how the Rockville's sound compares to the Mini Karlsonator (0.53x) with the PA130? I am interested in making a pair of the Rockville's.
Thanks, yatr98
Old 14th December 2020, 06:29 AM   #177
Got Foam?
xrk971's Avatar
They are very different speakers. The Rockville's are neutral and accurate nearfield "monitors" and have the top end afforded by a dome tweeter. They play all genre's well and accuratey, however lack bass below 90Hz or so. In nearfield (3-4ft) the bass is quite satisfying though - I can listen to them all day and don't really miss the bass normally afforded by my big 8in TL speakers. The 0.53x Karlsonator with PA130-8 has a similar voice, but is not a "monitor" and lacks the higher end reach above 12kHz. I would say the midrange on the PA130-8 sounds a bit more foreward. The bass on both is a toss-up, maybe with mid bass slam going to the Rockville, but ultimate deeper reach going to the Karlsonator with PA130. But that could be the difference in a stiffer wooden cabinet vs a foam core cabinet on the PA130 in a Karlsonator. I actually have them both connected, one on left and one on right for a comparison as I write this. The sensitivity of the PA130 is about 89dB so about 5dB louder.
They both sound great - but different. If you want to use them for casual listening, either works but for mixing or when accurate reproduction of all genre's is important, maybe the Rockville should be considered more suitable. Vocals on the Karlsonator can sound very mesmerizing.
However, Bonjonno really likes the 0.40x TC9FD Karlsonators for studio monitor work.
Old 14th December 2020, 03:26 PM   #178
Thanks very much for the comparison...and as always, still enjoying my PA130 Karlsonators!
Old 18th December 2020, 01:29 PM   #179
Got Foam?
xrk971's Avatar
Another set of Rockville’s is now singing in Long Island, NY! These belong to Vunce who did a super job with the crossover and final cabinet assembly. He reports that they sound great and are now playing with the FH9HVX driven by the Yarra/ACP+ preamp.
Cabinet construction internal detail showing oak battens which are glued to the cabinet with PL Premium at the corners but latex caulking along the lengths for vibration damping. All walls lined with Noico butyl and then covered with eggcrate foam. Weatherstripping foam is used in between the front baffle and the battens to provide an airtight seal and additional vibration damping. The construction with 9mm BB plywood makes for a light but rigid and well damped cabinet.
Old Today, 06:55 AM   #180
Got Foam?
xrk971's Avatar
My 3D model of the woofer pincushion bezel worked out well. Here is a test print to check the fit. This will make CNC of the baffle possible.
RST28F and DC130A Foamcore Homage to LS3/5A-f53ae498-3215-4f63-a7b1-38c4a1c30b71-jpeg
RST28F and DC130A Foamcore Homage to LS3/5A-a212c03d-1872-451a-96df-8679d08f6b42-jpeg
RST28F and DC130A Foamcore Homage to LS3/5A-22e1c119-4ee7-4eaa-bd47-bf4eb15cddb4-jpeg
I have been using the TDA7293 Xmas Amp by Jhofland to play the Rockville’s over the past couple of days (free open source design). They work very well together.
  Reply to this post
RST28F and DC130A Foamcore Homage to LS3/5AHide this!Advertise here!
Thread Tools
Low-Cost PMC-inspired TL Monitor with DC130A and DC28F xrk971 Multi-Way 156 24th August 2020 08:55 PM
Dayton Audio RST28F-4 new pair FS jimk04 Swap Meet 1 15th August 2020 09:14 AM
When do you need a mid? ES180TiA-8 and RST28F-4 DaveFred Multi-Way 4 4th July 2019 11:42 AM
foamcore on steroids hollowboy Multi-Way 0 25th January 2017 09:39 AM
foamcore rock12 Full Range 27 25th January 2016 07:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
