RST28F and DC130A Foamcore Homage to LS3/5A
Thread Tools
Old 23rd November 2020, 03:44 AM   #161
N101N is offline N101N
This started as a curiosity for me in this thread on suitable replacement drivers for a small speaker similar to the LS5/3A. I decided to make a small sealed speaker of the same dimensions as the LS3/5A (12in tall x 7.5in wide x 6.5in deep) with a goal to reproduce the typical response that it so famous for - but using modest (inexpensive) and readily availble drivers.
I think the secret (of the typical nonlinear response) lies in the crossover.
Old 24th November 2020, 03:33 PM   #162
Signal lost is offline Signal lost  United States
The second set has been finished a few days and finally had a chance to take some images. I highly recommend this speaker for its balanced sound and compact size. The sealed design allows for great flexibility in placement. Kudos to X for this little gem.
Old 24th November 2020, 03:37 PM   #163
zman01 is offline zman01  Bangladesh
Signal lost,
That's a nice build, well done! The stain is looking good under natural light.
Old 24th November 2020, 03:52 PM   #164
Thank you Zman.
The stain looked too orange at first but it is closer what I imagined now. The first set are much darker. The baffle cut out for the woofer is the only difficult part and a template would simplify that job.
Old 24th November 2020, 08:26 PM   #165
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Very nice work, SignalLost! Beautiful job with the mitered corners and flush pincusion rebate. I know how hard those are to do. I wish manufacturers would stick with round bezels, but I think the shape gives it a unqiue appearance that is less boring than a round.
I finally had some time to do a dry-fit of the drivers and baffle into the box with all screws. So far so goos. I need to solder up some crossovers now.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 24th November 2020, 11:56 PM   #166
Got Foam?
xrk971's Avatar
The Rockville’s are singing! I am using my 10F/RS225 FAST speaker XO PCBs because I was looking for a nicer looking solution than P2P on a plank. I should get a smaller PCB made as this one is overkill. Lots of space. Although that XO PCB fits perfectly on the floor of the speaker.
They sound great and the voicing is exactly what I expected. Balanced and natural.
File Type: jpeg FF461D5A-7C34-4E97-AE18-358DB87F387C.jpeg (446.3 KB, 48 views)
File Type: jpeg F60135C8-B87B-4FCD-9613-CBD2CF28D66C.jpeg (732.9 KB, 47 views)
File Type: jpeg AB3EAB38-CE24-41D5-83F3-B1C1075F9754.jpeg (325.6 KB, 46 views)
Old Yesterday, 01:01 AM   #167
Vunce is offline Vunce  United States
Come on X!
Your teasing me
Old Yesterday, 05:23 AM   #168
Got Foam?
xrk971's Avatar
Finally in stereo. Very very nice sounding speakers.
RST28F and DC130A Foamcore Homage to LS3/5A-21965b9c-7b58-47a4-9add-cce4914ab5a7-jpeg
File Type: jpeg 21965B9C-7B58-47A4-9ADD-CCE4914AB5A7.jpeg (357.9 KB, 40 views)
  Reply to this post
RST28F and DC130A Foamcore Homage to LS3/5AHide this!Advertise here!
Thread Tools
Low-Cost PMC-inspired TL Monitor with DC130A and DC28F xrk971 Multi-Way 156 24th August 2020 08:55 PM
Dayton Audio RST28F-4 new pair FS jimk04 Swap Meet 1 15th August 2020 09:14 AM
When do you need a mid? ES180TiA-8 and RST28F-4 DaveFred Multi-Way 4 4th July 2019 11:42 AM
foamcore on steroids hollowboy Multi-Way 0 25th January 2017 09:39 AM
foamcore rock12 Full Range 27 25th January 2016 07:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
