sb23nrxs45-8 simulations and reality
Old 4th August 2020, 10:50 PM   #11
AllenB is offline AllenB  Australia
AllenB's Avatar
It is important to separate the room from the speakers when you measure. Since you are testing the box alignment you need to hear nothing but the box. Bring the speaker into the room and put the mic right next to the speaker.
Old 5th August 2020, 06:32 AM   #12
GM is offline GM  United States
GM's Avatar
Originally Posted by KitQ View Post
I now think that they cancel each other in this region..........
You're right, take it out of the room, it's acting as a passive radiator.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th August 2020, 12:51 PM   #13
hifijim is online now hifijim  United States
hifijim's Avatar
Two things come to mind:
1) exactly what Allen B said... For low frequency measurements, do a near field measurement of the woofer, and a near field measurement of the port. I forgot the exact math on how the two responses are added together, but an internet search will tell you. The alternative way (which is both better and more difficult), is to take them outside on a large flat surface (i.e. driveway) and do a ground plane measurement.
2) measure the T/S parameters of your drivers. This is what denbret was getting at. In most cases, the sample to sample variation among drivers is such that the Fs, Qts, and Vas variations tend to cancel each other out. This is almost always the case with a sealed box, and most of the time it is true for vented alignments... but it is worth checking
Old 5th August 2020, 02:47 PM   #14
hweb is offline hweb
At low frequencies (<100Hz) the room almost always dominates the speaker response (in most domestic settings, anyways - a large hall or gym might differ). If you want to prove this out, move the speakers to another room with different dimensions (preferably one with different ceiling height). You'll probably see vastly different response.
BTW - This is the reason why I generally just build sealed enclosures for low bass and EQ as the room necessitates. Below ~100Hz the room is in charge.
  Reply to this post
sb23nrxs45-8 simulations and realityHide this!Advertise here!
22W/4534G00 or SB23NRXS45-8 or something else next667 Multi-Way 7 20th May 2013 07:47 AM
do poor simulations sometime miss reality? freddi Full Range 10 6th November 2007 02:48 PM
Power supply simulations and reality donít match! Kashmire Pass Labs 6 28th September 2004 12:21 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
