Where can i buy focal speaker surrounding, any tips??
Thread Tools
Old 27th July 2020, 06:19 PM   #1
tidybearm is offline tidybearm  United States
Default Where can i buy focal speaker surrounding, any tips??
Hello,
i just found out that my focal drivers rubber surround 5n411 and tweeter k120 are cracking , so i plan to fix it, any tips to do a quick fix or any place in USA that i can buy the rubber surround from,,as well as foam surround for the tweeter?
thank you in advance
Old 27th July 2020, 06:24 PM   #2
Galu is online now Galu  Scotland
Stating the model of Focal speaker would be helpful.
Old 27th July 2020, 07:22 PM   #3
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Springfield Speaker sells a pair of butyl surrounds for a 5" Focal unit. Check the measures of it. Measure your old ones precisely and search new ones following these specs.
Old 27th July 2020, 08:14 PM   #4
Thanks for making your edit in order to include driver details.
Might be my fault, but after a quick search I didn't find details on the 5n411 and k120 drivers that you mention.
Do you have any other information to help identify these drivers?
I include a link to the butyl surrounds mentioned by Lojzek. 2 Focal 5 Inch K2 Butyl Rubber Speaker Surround Repair Kit - Woofer
Old 27th July 2020, 08:32 PM   #5
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Ask and you shall receive, Galu:
http://site.diy-loudspeakers.com/dat...ver-datasheets
(The foam on my T90K's has finally disintegrated, as well)
Tim
Old 27th July 2020, 08:45 PM   #6
Thanks Tim!
These appear to be the drivers in question:
http://site.diy-loudspeakers.com/ima...FER_5N411L.pdf
http://site.diy-loudspeakers.com/ima...TER_TC120K.pdf
Learning all the time!
Old 28th July 2020, 09:37 PM   #7
thanks for all the quick respond and info , i truly appreciate
  Reply to this post
Where can i buy focal speaker surrounding, any tips??Hide this!Advertise here!
Thread Tools
3-Way speaker building help and tips oppaaa Multi-Way 17 4th May 2019 10:52 PM
Need an Electronics Technician in the Virginia State or surrounding. Formas Car Audio 1 12th July 2018 03:17 AM
Sealed speaker pro tips maggiesnmacs Multi-Way 1 11th March 2015 07:15 PM
WWMMTMMWW drivers surrounding the T crazyhub Multi-Way 23 17th December 2008 02:53 AM
MTM design FOCAL 6W4311 AND FOCAL Focal TC120 Tdx2 Bas Horneman Multi-Way 1 5th February 2003 05:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
