Speakers - Jantzen standard Z Cap or Mundorf M-CAP EVO
Thread Tools
Old 4th December 2020, 08:57 AM   #81
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Very useful things, clip leads, but remember if you're going to do that to check their resistance beforehand. I've seen people go grey prototyping filters via clip-leads, then discovering when the circuit is built up on a PCB or hard-wired onto a board that it doesn't behave the same way due to the altered cicuit resistance.
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
Old 4th December 2020, 09:41 AM   #82
Mattes is offline Mattes  Germany
Mattes's Avatar
Exactly. Clip leads, especially the cheap chinese ones, have a considerably high resistance, and if you´re using quite a handful of them in a quick XO mock-up, they can quickly screw up what you´re doing.
Of course it´s more work, but despite the fact that I have plenty of them, I try to avoid use of clip leads whenever possible.
All the best
Mattes
Disclaimer: I´m the international distributor for FERTIN ACOUSTICS fullrange drivers and am thus biased by commercial interest. Please have a look at https://guentherengineering.com for further information.
Old 4th December 2020, 09:50 AM   #83
Mattes's Avatar
Originally Posted by diyiggy View Post
I'm very curious about that as I'm only tried the Jantzen Cross-Cap. Can you sumarize fastly please the main difference between the superior and the standard please ?
Hi Iggy,
Was that question aimed at me? If so, in my personal opinion, the Sup-Z sounds more detailed than the Standard-Z, and in the same time less like there´s anything in between amp and speaker. For a high quality system, IMO it makes sense even with large values, but that all depends. If you´re using mid-fi drivers, it will make no sense to invest a few hundred bucks into caps, better get a better driver for your cash.
But when you feel that you do have the best driver for your application, it might be worth it.
Just to keep things into perspective: I actually do sell Jantzen parts, but very seldom. Just remember to read my words with a grain of salt...
All the best
Mattes
Old 10th January 2021, 11:57 PM   #84
33Polkhigh is offline 33Polkhigh  United States
33Polkhigh's Avatar
I don't see how a good quality capacitor could add brightness to the sound. Its a filter and so can't be any brighter than an active crossover. A junk capacitor can add brightness though.
I just bought a Jantzen crosscap for a first order filter for a build. My decision was influenced by listening to a cheap junk capacitor for a test. It worked but the junk cap sounded bad. I noticed a chirpy splashy transistor radio-like sound that was irritating enough that I had to take it out.
"And so they took their doughy fists and pounded upon me until a mutual consensus was reached that I leave."
Old 11th January 2021, 12:13 PM   #85
oldspkrguy is offline oldspkrguy  United States
I always experiment myself. Some capacitors add to much brightness on hard dome tweeters but seem to work well with soft dome tweeters. Others just the opposite; they sound too mellow on soft domes but work well with hard domes. I stand by the Superior Z as the best capacitor for the money. It's not inexpensive but considering it can even improve the sound of budget drivers, it is still worth it to me. Of course; I wouldn't put a $35 capacitor on a $20 tweeter in general. I have done that just because I had some on hand and yes, there were improvements even on something so cheap. I would never do this as a design goal however. When I am unsure of what values I may need; I have a lot of the Audyn Q4 capacitors of many values. They are quite good for the cheap price and sometimes that is all you need. So I start with these until I am satisfied with my results then I upgrade to a higher quality if the drivers or design warrants the extra expense. Sometimes it just comes down to listening preference and personal tastes.
  Reply to this post
Speakers - Jantzen standard Z Cap or Mundorf M-CAP EVOHide this!Advertise here!
Thread Tools
FS : Jantzen coils, Mundorf Coils, Jantzen Audio Cross-Cap Capacitors gdan Swap Meet 7 18th June 2020 12:01 PM
Jantzen Vs Mundorf Vs Solen Vs others bowdown Multi-Way 58 22nd January 2020 06:34 PM
Mundorf Supreme, EVO, Audyn, jantzen, russian caps, Mundorf Resist, XHadow, KLEI rca edbk Swap Meet 20 24th June 2015 01:37 PM
FS: Jantzen Standard Z caps budwiser Swap Meet 6 23rd April 2013 04:12 PM
Mundorf CFC Vs Jantzen Waxcoil diypass Multi-Way 1 16th January 2013 09:43 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
