Subwoofer for an VOT A7
Old 6th July 2020, 07:43 AM   #41
jakruby is offline jakruby  South Africa
So seal the 416 into the "upper" compartment. Mount a woofer in the new "lower" compartment and all of said woofer's output will exit through the port. What kind of enclosure would that be? Surely you would want some direct sound from the woofer and use the port to augment lower end?
Old 6th July 2020, 12:54 PM   #42
Pano is offline Pano  United States
Pano's Avatar
You're half way there.
Close off the woofer into it's own small box. Like putting a partition just below the woofer horn. Now you have the whole lower box (maybe 10 cubic feet) to use has your subwoofer enclosure. You replace the front baffle with a new baffle that has your subwoofer driver in it, along with the new ports you need for that subwoofer. Just like any normal bass reflex cabinet.
Your 825/828 cabinet now has two chambers. An upper chamber that contains the woofer and its horn, and a larger chamber that is your subwoofer.
Take the Speaker Voltage Test!
Old 6th July 2020, 02:18 PM   #43
Pano's Avatar
This is where a picture might be worth its 1000 words.
You would add ports to the lower section if doing bass reflex.
Old 6th July 2020, 03:17 PM   #44
Pano's Avatar
Here is a more accurate drawing and more to scale.
Old 7th July 2020, 02:49 AM   #45
GM is offline GM  United States
GM's Avatar
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th July 2020, 02:59 AM   #46
GM's Avatar
Originally Posted by jakruby View Post
So seal off the front of the horn and just use the port?
I knew sure as I didn't post a link, someone would misunderstand.
Unfortunately, the original threads are MIA and some of these may be duplicates, just copied what I could quickly find doing a search of me [GM] and [2245] for the ones done using the JBL 2245H since at that time the Altec 411 I used was basically MIA since GPA couldn't do a proper recone even if a motor basket could be found, so in no particular order:
Getting more bass out of 825-828 cabs
would a 411 8A make a good speaker for a sub?
A7's with subs?
A Frenchman's version: Altec voix du Theatre A7/A5 anybody done this?
What to do with Altec A7 cabs..? | Audiokarma Home Audio Stereo Discussion Forums
http://www.hostboard.com/forums/f700...light=jbl+2245
Only picture I could find: https://www.hostboard.com/forums/att...l-2245-sub-jpg
GM
Old 8th July 2020, 07:04 AM   #47
Excellent resources - thank you
Old 8th July 2020, 09:14 PM   #48
freddi is offline freddi  United States
freddi's Avatar
Exemplar's solution to a subwoofer which "kept up" with their VOT-like horn/reflex speaker, was to use the old Karlson K15 cabinet with low fs Altec 515 and for original K15, make a port adapter using two 3 inch ID right angle "Street El" (I used regular PVC elbows)
K15's original port was 9 inches tall by 4.5" wide them narrowed in 1956 to 3.5" width so the port adapter is a perfect fit.
I can't understand what the front chamber involvement would be in the sub frequencies but it sure sounded really good and adept with my 4168Z and a 15 watt per channel JC Penny receiver on theatre organ recordings using a Behringer analog xover. (the high frequency speaker was a Karlson "12" with wimpy Knight coax (which had a pretty midrange - but impact was like a Nerf ball-bat against a feather pillow)
swivel those vents to so they are parallel with the shelf for better looks and clearance
some of the magic must be from the Altec having lower mass than many of today's speakers whose fs is in the 20's
Old 8th July 2020, 09:56 PM   #49
freddi's Avatar
that is a cool idea to close off behind the woofer as a regular FLH then use the huge volume for a sub of sorts
Here's a 56 liter back chamber
Old 8th July 2020, 10:56 PM   #50
GM's Avatar
Originally Posted by freddi View Post
I can't understand what the front chamber involvement would be in the sub frequencies.........
Well, my factory 515Bs had a near spot on 20 Hz Fs from the factory, ditto the two I had re-coned by the distributor when asked to match their specs.
Anyway, as you know these are only ~2 octave devices, so for 20 Hz it's down many dB by 80-100 Hz unless coupled to a ~matching impedance, so the front chamber sets a BP's HF response above its tuning, ergo reduce its net volume [Vb] if wanting to flatten it out or to a rising response out to its HF corner, which is a good thing when matching up to a compression horn, especially if corner loaded.
GM
  Reply to this post
Subwoofer for an VOT A7Hide this!Advertise here!
FS in Los Angeles: subwoofer, subwoofer cabinet, oscilliscope, KEF center... taloyd Swap Meet 81 1st February 2020 09:46 PM
Overview about words largest Subwoofer Drivers/Transducers (SUBWOOFER BEAST) tiefbassuebertr Subwoofers 27 9th September 2012 09:42 AM
FS: Dayton Reference Subwoofer RSS315HF-4 12" Subwoofer Driver matevana Swap Meet 0 12th February 2012 02:42 PM
Subwoofer build - Morel UW1258, 12" Ultimate Subwoofer mantha3 Subwoofers 46 10th October 2011 01:11 PM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
