First time DIY - Reality check
Old 30th June 2020, 03:39 PM   #11
Mike56 is online now Mike56
Originally Posted by S4dp View Post
Hi! Fusion Bad surely looks pretty badass
You will find my notes and pics on his builders pages. I think i might well have built something else if i knew then what i know now! - not that there is anything wrong with what I've done, but i don't use high levels and might have placed a different emphasis, there are so many nuances, my advice do lots of research and trust the experts! - i find it difficult to even ask the correct questions!
PC, to Chordette GEM DAC or O.L. Aurora4 with Onyx arm Rega Ania to Graham Slee MC pre, to Prima Luna Prologue 1. Troels Gravesen Fusion BAD with Hypex 151's high level input
Old 30th June 2020, 03:45 PM   #12
YSDR is offline YSDR  Hungary
YSDR's Avatar
I share the view that 4-way is unnecessary with these drivers. The 22W can go up to 400-500Hz easily and from here you can go with the 12W or a 15W to the tweeter.
Btw, the very low passive crossover in the 4-way can cause additonal problems which is not showed in your simulations. (See below)
Why you don't like 4 Ohm speakers? What is your amp?
Passive woofer crossover peaking issues
Old 30th June 2020, 04:54 PM   #13
hifijim is offline hifijim  United States
hifijim's Avatar
Yet another opinion that a 4 Way is not necessary or even desirable with an 8 or 10 inch bass driver. Most of the good 4 ways are designed more like a good 3 way, with the addition of a built-in subwoofer. If your low frequency driver was a 15 inch, then yes a 4 way might be an advantage over a 3 way.
Old 30th June 2020, 05:44 PM   #14
Hey guys, first time DIY here.
The idea was scan-speak drivers using their revelator series [/LIST]
Troels did these
Ellipticor-3
And recent updates as well
Old 30th June 2020, 06:22 PM   #15
S4dp is online now S4dp
Hi!, Alright.. Maybe the 4way was a bad idea afterall . Im currently rocking a hegel h90 but im actually planning upgrade that to something like a luxman or something similar.. TBD.. About the 4ohm i just liked the idea of 8ohm, not much more to it except it easier to drive on more widely variety of amps. In the end maybe 4ohms is the way to go in my case with perhaps a 3,5 way
Old 30th June 2020, 06:27 PM   #16
Originally Posted by Mike56 View Post
Troels did these
Ellipticor-3
Saw ur build, looks sick
Well done
Ellepticor seems quite abit harder to build but they surely look good!
Old 30th June 2020, 11:46 PM   #17
diyiggy is offline diyiggy
diyiggy's Avatar
Did you consider this option as you have a reference : Keep one as a reference.Take one of the tower with the filter outside with longer wires going outside from the BR port and work on it on a wood piece to adapt to your room, tastes & learning project ? (Ask anyway a little mic and soundcard investment).
Old 1st July 2020, 12:38 AM   #18
AllenB is offline AllenB  Australia
AllenB's Avatar
Many people do it perfectly. In the link, the member made unusual choices.
Old 1st July 2020, 05:38 AM   #19
YSDR's Avatar
Maybe, but for first time DIY? What is so unusual in the link that the member made? I didn't see any.
I still think that a 4-way is unnecessary with these small drivers but if someone wants a 4-way then it's his choice.
Old 1st July 2020, 05:54 AM   #20
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Nope Go 4-Way
But be prepared for a lot of time and effort if passive. 3-Way with powered subwoofers will clean up the midbass and really allow the midrange to shine
The question really is how fat is your wallet? Clean deep bass is going to be expensive, more than I can afford at the moment but I see nothing wrong with using 10" woofers as a mid-bass unit and going to 15 or 18" for the sub, crossing over as low as practical
I cheat tho, I use affordable Behringer crossovers for bass/mid-bass/midrange cross and fiddle with passive for the top
Please excuse the crappy photo and even worse woodwork/painting
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
First time DIY - Reality checkHide this!Advertise here!
Reality Check or is it Possible? mortron Class D 3 13th June 2017 01:31 PM
first sub build reality check kcducttaper Subwoofers 18 3rd March 2015 11:48 PM
Reality Check DIY Tannoy RichardP Construction Tips 0 26th January 2014 10:25 PM
Reality Check jdlech Multi-Way 11 26th January 2008 05:55 AM
Reality check analog_sa Chip Amps 2 10th November 2003 09:30 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
