Frequency Response Match for Older Ears
Old 26th June 2020, 03:13 PM   #11
chris661 is online now chris661  United Kingdom
chris661's Avatar
There's definitely potential for <60Hz content, even if your ears can't "hear" it, you can still feel a tactile response. You'll find deaf people at concerts for that reason - they can still feel the bass.
I do know some people with a little hearing loss will deliberately increase the treble levels in order to compensate. That would result in their system conforming to their internal reference of what things ought to sound like, but doesn't correlate with an external reference like someone playing an instrument in front of you.
Chris
Bits of information and other things I've worked on: https://www.grimshawaudio.com/lab
Old 26th June 2020, 03:27 PM   #12
freddi is offline freddi  United States
freddi's Avatar
I would guess it could be desirable to have good power response/off axis dispersion to 6KHz and treble extension an octave higher to 12KHz as there may be sideband activity from harmonics reaching into that upper region of your measured hearing.
Old 26th June 2020, 03:35 PM   #13
jjasniew is offline jjasniew  United States
jjasniew's Avatar
Originally Posted by classicalfan View Post
then why even worry about a multi-way when a full range driver will cover most of the range I can hear.
IMHO, multi-way is for power handling (power divied up across 3 VCs dissipates better than one) and flat frequency response (bandwidth divied up across 3 optimized drivers is flatter than one).
For me, one of the things that also goes with age is the joy of SPL - sounds like a book title. When I was younger, I used to enjoy steeping myself in it. Not so much these days; when Skynyrd says "turn it up", I turn it down.
So what's left? Coherence through the frequency range I can hear. I can still enjoy a good soundstage projection. There's still "focus" of different instrument placements within that's enjoyable to fathom. I like an acoustic bass to sound like an acoustic bass is standing there, placed between my speakers, which can happen on certain recordings.
Dynamics is also appreciated still. There's a few tricks to getting that, very efficient speakers (another + for FRs) is just one, some say having 2nd harmonic (from single ended tube amplification, "Lampization", etc) is another. The folks with the SET amps and very efficient speakers could be onto something, regarding "older ear" enjoyment from this perspective. I have a toy that's a VST plug-in which does multi-band dynamic expansion. It can be set to create a subtle, yet makes-a-difference effect.
Certainly the gut-punch of a powerful, effortless low distortion sub is still perceptible even at lower, reasonable volume levels. There's a dimension that can be worked on to achieve some satisfaction, perhaps compensating some for age related losses at the upper end
Joe Jasniewski - PC>ZOUDIO AIO4CH> OB Lii Audio F15s w/ 18" assists.
Old 26th June 2020, 03:37 PM   #14
phase_accurate is online now phase_accurate
It might probably be a good idea to have a switchable personalised EQ in order to compensate for the hearing loss a little. If it can be switched off the stereo could be used by others in the same household with normal hearing without getting earbleeding. And that would definitely mean the use of a capable tweeter - although it would definitley not need to go to 40 kHz.
There is usually (!) no hearing loss at low frequencies with age. Maybe you didn't test loud enough (keep the equal loudness curves in mind when doing that) or the test equipment didn't go low enough.
If someone is suffering from tinnitus it may probably be nice (depending on the type of tinnitus) to add a switchable notch filter (in both channels for phase equality even when only one ear is affected) also.
Charles
Old 26th June 2020, 03:51 PM   #15
Galu is offline Galu  Scotland
How much extension on the both the low end and high end do we really need as we get older?
Linearity is likely to be more important than frequency range. We oldies can tolerate frequency loss in music at both ends of the audio range, but our ears are distressed by undue prominence in any section.
Old 26th June 2020, 04:05 PM   #16
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
It's called trough-bone (endo-ossean) hearing...
there’s no staying at home when you do not have one
Old 26th June 2020, 05:43 PM   #17
jjasniew's Avatar
Ah yes, I forgot to mention tonal balance within the range you (we...) can still hear, i.e. that what you would hear and prefer when listening in mono. This is not something I know much about, except that it's a parameter some swear by.
I bought my speakers in part because one guy hawking them said they reproduced the sound of a piano better than any of his other products. There's a piano in the house, which gets played regularly. Sometimes...
Old 26th June 2020, 06:38 PM   #18
classicalfan is offline classicalfan  United States
Originally Posted by analog_sa View Post
But what's with the 60Hz? What makes you think you cannot hear lower frequencies?
Not sure exactly about 60 Hz, and can't find the results from my last test right now. But certainly didn't go down to 20 or even 30 Hz.
Old 26th June 2020, 06:57 PM   #19
Originally Posted by Pano View Post
... How good is your sense of pitch, level change, distortion, direction? All of those things are important to keen hearing, young or old ears.
That's what is interesting. All of those are still excellent. I hear distortion when other people don't and it drives me nuts. I bought my wife a Bose (Sonos type) speaker for listening in the kitchen and I can't stand to be in the same room with it. Terrible, terrible distortion. Tested the Sonos in the store first and it was worse.
Since I listen mostly to classical music things like dynamic range and transient response are very important and I don't sense any compromise in them. At least not yet.
Old 26th June 2020, 07:05 PM   #20
And that would seem to support AllenB's comment above for a preference of a multi-way over a full range speaker
Frequency Response Match for Older EarsHide this!Advertise here!
Building an arm to match cartridge resonant frequency. tribute Analogue Source 9 9th January 2018 09:06 AM
Better frequency response? Insanoff Parts 3 25th September 2013 03:07 PM
in-room frequency response & transient response MCPete Room Acoustics & Mods 1 8th October 2011 06:31 AM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 10:39 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
