Combining cross overs
Old 30th June 2020, 10:36 AM   #11
EarlK is offline EarlK  Canada
Here's an example where it's not really practical to combine the 2 functions of HiPass with that of Response Flattening .
This "Trace" belongs to "grahamgraham" .
Old 30th June 2020, 01:59 PM   #12
Kris,
Here's an example of a filter that combines the functions of the HiPass with that of a HF Compensation Circuit ( which flattens the overall HF response ).
This is one of my Peerless drivers on a 152i Clone wavequide.
BTW; R1 + R2 are bypassed here ( iow; they are not in circuit so ignore their presence or values ) ).
- The same "out-of-circuit" observation applies to the 2 pictured PEQ circuits seen ( L4,C4,R4 + L3,C3,R3 ) . They aren't active + are not there ( functionally ).
Combining cross overs-3-pole_simple_ek_2i2_-png
This filter also employs a mild "Bump-Filter" ( at cut-off ) to PEQ boost a small area .
Here's a shot of the filters transfer function.
Combining cross overs-3-pole_simple_ek_2i2_filter_-png
Again, this combo approach is only doable when the HF response presents a "good-enough" straight line.
These simple horn circuits are quite widely found in many Sound Reinforcement crossovers.
Old 30th June 2020, 05:06 PM   #13
Here's a look at one way to handle the gentle roll-off curve seen in grahamgraham's trace of the Peerless driver on the STH100 waveguide.
Again, C2 is shorted and the LCR notch ( L3,C3,R3 ) isn't engaged.
Combining cross overs-2-pole_peq-hf_ek_2i2_-png
The red curve ( seen above ) is the raw response ( I've used a zma file from my own files to make this happen > so the simulation is only so-so ).
And here's what the electrical filter is actually doing along with an impedance trace.
- Both "Peaking" filters betray their presence ( when looking at the dips in the overall impedance ).
Combining cross overs-2-pole_electrical-impedance_ek_2i2_-png
File Type: png 2-Pole_electrical+Impedance_ek_2i2_.PNG (54.6 KB, 17 views)
Combining cross oversHide this!Advertise here!
Cross overs and Bi Wiring Roobarb Multi-Way 12 26th November 2016 01:30 PM
Zaph ZRT cross overs orangeart Multi-Way 0 11th November 2014 08:05 PM
Chips for active cross overs ChrisA Chip Amps 10 5th April 2010 07:55 AM
Building Subwoofer Cross Overs? Dominick22 Subwoofers 15 22nd September 2006 08:15 PM
Capacitors for Cross-Overs 2x6spds Parts 1 14th November 2005 01:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
