More Midrange Sweet Spot
Old 30th June 2020, 01:24 PM   #51
grayxxx is offline grayxxx  United States
Originally Posted by Pano View Post
For years I ran a PA that used a front horn loaded 10" midrange. Horn tweeter above, woofers below. Worked well enough. A wide midrange sweet spot was not the goal, but it did have good coverage.
A PA from GM's neck of the woods. OAP.
PANO.....If you gang up with GM....Im going to do it .....Im thinking about running away from home.......to live behind "Dairy Queen"..or join the circus.and take my computer 2" X 8 speaker array with 1/4" x 1/2" ports running a 3 watt power amp at .00000001 amp load...you will be sorry ....if you come for ice cream or to barrow the array....for a conference call small array PA job...
My sweet spot mid back ground mid presents with the mid horn or by speaker
with pot. was in stereo use, but that may applied for PA..You dont think 10"
midrange with a mid horn adjusted in the back ground of the speaker mids would not give a depth of field of the mid sound.. vs. both mids at same volume.
Old 1st July 2020, 11:22 PM   #52
Pano is offline Pano  United States
Pano's Avatar
You would likely end up with much comb filtering and lobing. How much depends on many things, like driver offset, volume, horn profile, etc. It's not something I want to try, but who knows, you might like it!
Take the Speaker Voltage Test!
More Midrange Sweet SpotHide this!Advertise here!
Sweet spot ludl Pass Labs 3 16th October 2019 07:17 PM
sweet spot rock12 Full Range 3 23rd January 2013 09:39 PM
300B Sweet Spot tomchr Tubes / Valves 8 14th December 2010 05:42 PM
F4 sweet spot... Skorpio Pass Labs 3 17th June 2010 08:31 PM
The Sweet Spot Nelson Pass Pass Labs 54 12th November 2009 01:53 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
