Egg-closures
Egg-closures
Old 29th June 2020, 11:56 PM   #51
chopchop is offline chopchop
Just filled up an egg with water. I measured 8 litres, the manual says "Speaker effective internal volume: 14 Litres". Eggsplain that!
Old 30th June 2020, 01:53 AM   #52
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Egg-closures
I’d trust the water
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 30th June 2020, 08:11 AM   #53
AllenB is offline AllenB  Australia
AllenB's Avatar
Egg-closures
2 x 8 minus some for the drivers is near 14l?
I'm going to poach that idea.
Old 30th June 2020, 08:43 AM   #54
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Egg-closures
Copy paste of the 150 specs?
Old 30th June 2020, 09:01 AM   #55
Gracol is offline Gracol  England
That's what I'm wondering. 8 litres certainly seems more realistic for the 830870.
Old 30th June 2020, 01:32 PM   #56
Yes, a mistake I think. Egg 100 manual also says
"Bass reflex speakers with 70Hz QB4 front port alignment"
Egg 150 manual says
"Bass reflex speakers with 50Hz QB4 front port alignment
Also a 2k crossover to a Monacor SPH-165 on the 150s, which is lower than the 2.5k Monacor recommend for the tweeter. Hence the "Thermal tweeter protection with automatic cut out and reset" !
Looks like they go up to 145 degrees C here Resettable Thermal Fuses RS Components. I wonder what temperature you'd need to prevent a fried egg?
Edit: Just noticed the Egg 150s have a common ground connection for the drivers so they use 4 pole Speakons with 1 pole for the LED.
Old 30th June 2020, 04:35 PM   #57
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Egg-closures
Those stands look Eggsquisite!
Old 30th June 2020, 05:34 PM   #58
diyiggy is offline diyiggy
diyiggy's Avatar
Looks like flying in the air and sound seems not come from them directly...
... totally Eggs Nihilo
Old 5th July 2020, 02:33 PM   #59
garym999 is offline garym999  United Kingdom
For me, this my longest print ever an epic 22 hours of hatching and my first ever printing with flex. Lots of stringing and print artifacts but some of that I should be able to tune out.
They have a honeycomb in fill and that makes them softer when squeezing from the sides but not so much from top to bottom.
The stands are soft and have the desired effect of preventing the speaker from sliding around as they do on the Orange prototypes.
Spose I'd better sort out the speakers next.
__________________________________________________ ___________________________________
“There are only 10 types of people in the world: those who understand binary and those who don’t.”
Old 5th July 2020, 02:36 PM   #60
Pano is offline Pano  United States
Pano's Avatar
Egg-closures
Most eggcelent! Love it.
Egg-closuresHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
