Egg-closures
Egg-closures
Old 22nd June 2020, 06:58 PM   #11
chopchop is offline chopchop
Originally Posted by chopchop View Post
The tweeter and Speakon rear connector holes have not been threaded.
Correction - on closer examination, the tweeter holes have a metal M3 threaded inserts. The woofers have M4 inserts.
Old 22nd June 2020, 08:33 PM   #12
Charles Darwin is offline Charles Darwin  United Kingdom
I am eggcited.
Old 22nd June 2020, 08:37 PM   #13
diyiggy is offline diyiggy
diyiggy's Avatar
chief's omlet
Old 22nd June 2020, 08:49 PM   #14
Pano is offline Pano  United States
Pano's Avatar
Egg-closures
Let's hop ChopChop doesn't end up with egg on this face
Old 22nd June 2020, 08:56 PM   #15
diyiggy's Avatar
I just can imagine the bird size !
We will see more an more things like that with the 3D printing progress... with many diferent materials, metal even. Cost greatly decreases... and molds will be a souvenir.
Old 22nd June 2020, 08:59 PM   #16
Eggzackerly!
I've just realised the rear Speakon socket is probably fitted using nuts and bolts rather than cutting a thread into the plastic. Accessed through the woofer hole.
Old 22nd June 2020, 09:03 PM   #17
Pano's Avatar
Egg-closures
Yes, that's likely. Cool that it has the Speakon cutout. And also cool that it has the threaded inserts for the drivers.
Have you hatched a plan?
Take the Speaker Voltage Test!
Old 22nd June 2020, 09:08 PM   #18
Almost! Still wondering about the egg cup needed. The originals come with rubber ones so maybe I can cut some rings out of foam. Could put a wig on the pointy end for extra diffraction.
Old 22nd June 2020, 09:44 PM   #19
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Egg-closures
Not sure I could shell out the money for them but you guys and your humour, really crack me up.
Old 22nd June 2020, 09:50 PM   #20
Well it's certainly a fertile environment for ideas round here. Just looking at the Egg 100 photos, I think the 4" driver is a fancier one than the SDS line. It looks like one with a cast aluminium frame rather than stamped.
Egg-closuresHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
