A Monster Construction Methods Shootout Thread
Thread Tools
Old 28th March 2021, 07:57 PM   #301
augerpro is offline augerpro  United States
Versions 4 and 5 of the AugerPort are in!
AugerPort 4 results:
AugerPort 5 results:
Comparing the AugerPort 5 versus the Harman contour it is based on shows the huge improvement in knocking down the pipe resonances:
The issue with all of these is much worse harmonic distortion. To add some data points I did a simple single tone spectrum analysis and you besides the harmonic distortion products, you can see broadband noise in from 500-5000hz that is not present in the Harman, and broadband noise in between the first 4 harmonics that only become an issue in the Harman at higher voltages. Making progress so I'll keep working the tap shape.
~Brandon
Please help my waveguide and box construction research by donating to my gofundme via my website:Soma Sonus
Old 28th March 2021, 08:47 PM   #302
454Casull is offline 454Casull  Canada
Really impressive, looking forward to what's coming next!
Old 29th March 2021, 02:32 PM   #303
Fascinating video on acoustic metamaterials: Acoustic Metamaterials with Steve Cummer - YouTube
~Brandon
Old 29th March 2021, 05:14 PM   #304
Sin Phi is offline Sin Phi
@augerpro since you are on a port kick you might be interested in this Polk Audio Reserve Series Loudspeakers Press Event - YouTube Polk's new speakers have a resonator tuned to the resonance of the port in the throat of the port. Looks extremely good on the response charts they showed. May be a lot easier to implement and design parametrically when compared to a soft material method. Don't know the patent number or have technical implementation details, but I would guess that the 2 resonators are tuned around the 1/4 wave frequency of the first resonance to broaden the filtering notch and lightly damped with polyfil.
Not sure what your intentions are with your ports, but from what I have been seeing the Harmen port is ideal for a sub and shouldn't need the resonance reduction. Looks like there is still some opportunity to find a lower distortion port that reduces the resonance for woofers/midwoofers.
Old 29th March 2021, 05:16 PM   #305
It's resonators all the way down...
Turtles all the way down - Wikipedia
Old 29th March 2021, 08:13 PM   #306
ergo is offline ergo  Estonia
That Polk port idea is interesting, but I would totally disagree with a "ETF not needed on subwoofer as the resonance is out of band" It's not out of band for the listener who is listening - far from that, so reducing a port resonance would still make sense. They should just say it saves them on cost and maybe the effect is a bit weaker so they skipped it.
Old 30th March 2021, 01:16 AM   #307
It looks to me to simply be a closed end pipe, with taps in the center, which is also aligned with the center of the port, I'm guessing it's dampening the 1/2 wave. When he shows all the pieces together it doesn't look like there is anything inside the resonator to damp the energy, just hollow? Certainly if anyone can explain what is going on there and how that might inform dimensions I could easily print something similar.
I do wonder that how the harmonic distortion looks, though he does say it chuffed later, so that is promising. That is my main issue, I'm quite happy with the pipe resonance dampening in this last round of designs, but it seems unavoidably to come with worse HD and chuffing.
~Brandon
Old 30th March 2021, 03:41 AM   #308
Yeah, my take away is that you get the strong port resonance reduction with possible low distortion. My assumption on the damping is that they mention "appropriately damped" a few times when talking about the port resonators and the cabinet column resonator.
Looking at your figures lets assume there is a strong resonance centered at ~1900 Hz. If we want resonators at 1800 and 2000 at 1/2 wave they will be 8.5 cm and 9.5 cm. Judging from the images of the cutaway this seems to be more in the ballpark for the floorstander dimensions than 1/4 wave. I wouldn't be able to say on the diameter of port and resonator, by my eye the resonator looks to be ~1/4 the diameter of the port throat. If I were to damp it I would try at the point of reflection and at the inlet. At the inlet it could help to smooth the filtering like for the meta material absorbers. Should be light and not stuffed so as to not affect the tuning.
A thought I am having is they mentioned that the reduction in resonance peak gave a reduction in distortion because of the distortion in that frequency band. But, that would be with a flared ended straight port. The Harmen port does not have significant distortion at the resonance peak, so you may not get the benefits of both concepts here. Hopefully it won't distort as much as the slotted and damped port though.
Given that for a port you could 3d print the mount and inlet you could try a lot of different resonator lengths out with some thin wall pvc.
Old 30th March 2021, 01:24 PM   #309
It kind of looked like the resonators were the same length as the port? Like a parallel port sitting inside the main port with probably the same pipe resonances, but damped and open in the middle to capture some of the main ports energy too?
~Brandon
Old 5th June 2021, 09:54 PM   #310
Tried a new CLD box using 1/4" Hardie backer board, a type of cement and paper composite board. Similar to earlier simple CLD boxes I did, the Hardie board was the internal layer, 1/4" MDF as the outer layer, glued together with Loctite PL300. I reran harmonic distortion for some earlier boxes that tested well because I couldn't remember how my test rig was setup. This time I included the THD% so you can just compare a value instead of the mental gymnastics of finding the difference between two wiggly lines.
~Brandon
A Monster Construction Methods Shootout ThreadHide this!Advertise here!
Thread Tools
JLH Mosfet Power amplifier construction thread jamesfeline Solid State 57 17th May 2021 09:10 PM
Studio 350 construction thread jamesfeline Solid State 49 30th September 2019 09:19 AM
monster-6-channel-amplifier-build-thread matt09 Solid State 8 12th April 2016 09:44 PM
Krill construction thread - Sidetracked quoydoy The Lounge 43 12th March 2009 07:51 PM
Ultimate NOS DAC Construction Thread iggy80fr Digital Source 1 11th November 2007 04:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
