Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Multi-Way Conventional loudspeakers with crossovers |
Thread Tools |
#261 |
Here are the results of the new port test. Here I wanted to investigate a few things. One was abandoning the Kef method of flexible center sections to reduce pipe resonances, and go to tapping the center of the port and then dampening that energy. I also wanted to investigate whether the performance of the Harman port was inherent, or whether it was simply due to the average port diameter being larger than the others (thus it being longer than all the others also). I did this two ways.
First by downsizing the Harman port so it matched the overall length of my Precision port clone. Port ID ended up at 1.756". Since I hadn't yet determined an end correction factor, I had to make an educated guess and the final port tuning was high by about 2-3hz. Not bad. Second, I upsized my Precision port clone so that the overall length was the same as the original Harman port. Port ID is 2.28". Tuning was virtually identical. I also measured an actual 2" Precision port to see if surface finish made a difference. If you recall I 3D printed all of these to remove the surface finish variable, since that is known to have a measurable impact on performance. Additionally I added a 2.38V harmonic distortion plot to better capture typical listening conditions. Harman port (shorty) ![]() ![]() ![]() ![]() ![]() ![]() ![]() Precision port (jumbo) ![]() ![]() ![]() ![]() ![]() ![]() ![]() Precison port (factory smooth finish) ![]() ![]() ![]() ![]() ![]() ![]() Tapped port I should note that I heard (and measured) a "flapping" sound during the harmonic distortion tests. No doubt the taped cavity being pumped back and forth. So treat these HD results as preliminary until I can print the dampening cavity, so it is sealed with hard material. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
~Brandon Please help my waveguide and box construction research by donating to my gofundme via my website:Soma Sonus |
#262 |
I tested with neoprene, it sealing so keeping LF port response, and flexing enough to notch down first port resonance.
#263 |
Some observations...
The Harman port is superior. It's a bit ahead in distortion performance for the original vs jumbo Precision port, and more definitely in the shorty Harman vs the original Precision port. Behavior at the very highest levels is where the difference is pretty large. Surface finish matters. Quite a bit. The harmonic distortion of the actual smooth finish Precision port is cleaner than my clone, and is really noticeable at the highest power. Not enough to catch up with the Harman though, but close. Close enough that smoothing the Harman print is well worth the effort. I've seen if you print with ABS you can smooth the finish with acetone. For some reason the F1 was not quite as smooth in the distortion plots this time around so it is not as obvious when chuffing starts when just looking at F1. The higher harmonics are still indicative though. Because of the difference in F1, power compression vs the earlier testing is a little harder to see.
~Brandon Please help my waveguide and box construction research by donating to my gofundme via my website:Soma Sonus Last edited by augerpro; 28th November 2020 at 08:40 PM. |
#264 |
Just wanted to share a fantastic paper. Harman's must be based on it. I actually like this paper's method better than Harman's for exactly the reasons that I diverged from Harman: normalizing based on tuning, not length, and later on length but with varying diameter so tuning was still the same. Curiously Roozen's worst performer (D) superficially looks like mine, BUT Harman did several variants where the changed ratio of length vs wall curvature radius. The one I selected was called N=0.5, which was sort of in the middle. At the high end of N there was much more curvature, and at the low end it looked pretty similar to Roozen's E. So I'm guessing his D was more like the N=1 port from Harman's paper. Still he specifies the optimal contour as like Harman (and his own D) but where curvature from port center to exit is not faster than 6 degrees. I'm going to try that, and tapping the port at 1/2 and 1/4 length.
#265 |
EDIT: N is actually NFR in Harman's paper
#266 |
Stupid question - did you try to stuff any of the ports with a light fluffy material?
#267 |
Nope
#268 | |
Sorry if already asked - have you tried alu-buthyl used in windows industry? Shore A value for soft glue ? I'm thinking about printing CLD using Shore A40 plastic.
email me jzagaja at gmail Last edited by jzagaja; 30th November 2020 at 02:32 PM. |
#269 |
Never heard of it. Know of a US source?
#270 |
Just sounds like aluminum foil laminated with butyl rubber.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
JLH Mosfet Power amplifier construction thread | jamesfeline | Solid State | 56 | 15th August 2020 09:28 AM |
Studio 350 construction thread | jamesfeline | Solid State | 49 | 30th September 2019 09:19 AM |
monster-6-channel-amplifier-build-thread | matt09 | Solid State | 8 | 12th April 2016 09:44 PM |
Krill construction thread - Sidetracked | quoydoy | The Lounge | 43 | 12th March 2009 07:51 PM |
Ultimate NOS DAC Construction Thread | iggy80fr | Digital Source | 1 | 11th November 2007 04:14 PM |
New To Site? | Need Help? |
