A Monster Construction Methods Shootout Thread
Thread Tools
Old 18th June 2020, 06:54 PM   #11
augerpro is offline augerpro  United States
Yeah I'm going to try various distances and angles and see what looks most informative and consistent before I decide on a standard.
~Brandon
Please help my waveguide and box construction research by donating to my gofundme via my website:Soma Sonus
Old 18th June 2020, 07:00 PM   #12
454Casull is offline 454Casull  Canada
Sounds good. It's a bit like the trick of using a side-firing woofer to minimize the bass distortion in the direct field (90-degree off axis response on a woofer is a really good acoustic filter for H3 and up, depending on where you cross it). Works especially well when you would otherwise get distortion peaks due to cone breakup.
Old 18th June 2020, 07:17 PM   #13
puppet is offline puppet  United States
Measuring the sound radiation of speaker cabinet walls
Might be some ideas in this article, too.
Old 18th June 2020, 08:38 PM   #14
Pygmy is offline Pygmy  Netherlands
For cabinet material, don't just stick to wood.
Slate stone, with its layered composition, dampens (damps? English is not my first language..) about 2.2 times more than MDF of the same thickness.
Boxenselbstbau - Gehausematerial - connect
(Article in german, use Google translate if needed)
("Schiefer" is slate in german)
I've built multiple speakers (and for optics, my amp as well :-) using slate.
The big towers (Heissmann Acoustics "Samuel HQ") use 2.8cm thick slate, which would come down to about 6cm MDF thickness :-)
They are DEAD :-)
Ordering it cut to size is pretty expensive, but I found out you can buy slate stone tiles pretty cheap (the small Needle speakers cost about $65 in tiles in total, 1.5cm thickness), and a $60 angle grinder and a $6 diamond blade cut through it like a hot knife through butter. I found it was just as easy to cut the slate tiles to size as it is to cut MDF!
It's heavy though - I build the big speakers horizontally on my bench, had to put them upright with help from my brother and had back-aches for two weeks after :-/
My guess would be they're at *least* 90kg a piece, maybe even over a 100kg...
Old 19th June 2020, 12:28 AM   #15
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
Add a surface 0.125" tempered HDF layer to the MDF or ply. It impresses me when I do that.
Wolf
Old 19th June 2020, 12:35 AM   #16
wolf_teeth's Avatar
Oh, and Roxul damping, also called safe n sound.
I also like rubber sport flooring and wool batting products. I doubt you can get 100% bamboo Naturfil anymore, but it was one of my favorites. Good ol' cotton balls for a cheap effective alternative. And maybe you can put the bubble-wrap mystery to bed...
I am rambling....
Wolf
Old 19th June 2020, 01:16 AM   #17
Wolf
I wanted to do that, thinking 1/4" HDF over 1/2" plywood might be a good combo but HD and Lowes were out of the HDF. It will happen though.
~Brandon
Old 19th June 2020, 01:58 AM   #18
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Please add melamine foam sponges (BASF Basotect) as liner wherever you would use felt or denim.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 19th June 2020, 02:07 AM   #19
Interesting. Know of a US source?
~Brandon
Old 19th June 2020, 01:31 PM   #20
Pano is offline Pano  United States
Pano's Avatar
Search for melamine foam sheets. Often sold for sound treatment in 1/2" and 1" thickness. Also sold in small blocks as a sponge, like Magic Eraser.
Take the Speaker Voltage Test!
A Monster Construction Methods Shootout ThreadHide this!Advertise here!
Thread Tools
JLH Mosfet Power amplifier construction thread jamesfeline Solid State 56 15th August 2020 09:28 AM
Studio 350 construction thread jamesfeline Solid State 49 30th September 2019 09:19 AM
monster-6-channel-amplifier-build-thread matt09 Solid State 8 12th April 2016 09:44 PM
Krill construction thread - Sidetracked quoydoy The Lounge 43 12th March 2009 07:51 PM
Ultimate NOS DAC Construction Thread iggy80fr Digital Source 1 11th November 2007 04:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
