Cone has a small dent/scratch. Audible?
Old 23rd May 2020, 02:21 AM   #21
Kustomize123 is offline Kustomize123
Originally Posted by afa View Post
But then it would be causing voice coil rub, and Kustomize has ruled that out in post#15
Okay so I get some rubbing if I just press on the cone with one hand. But thatís supposed to happen I believe. But if I use both hands, same distance from the dust cap, in opposite of each other, and then press down. I can press it down fairly smoothly and feel no rubbing.
Old 23rd May 2020, 12:37 PM   #22
Galu is offline Galu  Scotland
Yes, do not press down on one side of the cone as this may cause rubbing.
Always press down evenly on either side of the cone using your thumbs.
It would appear that you have no problem with voice coil rubbing.
Old 23rd May 2020, 02:50 PM   #23
Understood!
I am guessing its a production error.
Zaph|Audio - ZA5 Speaker Designs with ZA14W08 woofer and Vifa DQ25SC16-04 tweeter
I have the choice of using this in the Zaph 5.3T(2.5 way), or the Zaph 5.3C (center).
I was wondering how to get the most out of this driver without it affecting the sound? I could put it in the center because I don't watch too much movies anyway. So I'd barely have to go through whatever little impact this has anyway.
Second thing I was thinking is, I could use this as the BOTTOM part of the TMM. Which will only be in the bass region, and I believe this goes to 300hz I THINK, if I am studying the graphs right on the the link I posted above. Because till 300hz the measurements don't seem to that off anyway.
What do you guys suggest?
Old 23rd May 2020, 04:15 PM   #24
Either path sounds reasonable, but limiting the driver to bass duties would be what I'd try first.
Either way, listening tests are obviously required.
Cone has a small dent/scratch. Audible?Hide this!Advertise here!
Can a small inhomogeneity in the voice coil cause audible distortion (in a sub)? guferr Subwoofers 2 24th April 2020 06:03 AM
Small format cone driver in horn thread frangus Multi-Way 120 23rd July 2019 03:16 PM
Avermetrics AverLAB Scratch and Dent Sale AverPaul Vendor's Bazaar 0 8th August 2018 07:20 PM
Will a small cap value difference be audible? jb0194 Multi-Way 2 8th February 2012 05:39 PM
Dent in D6.8 Speaker Cone excetara2 Multi-Way 0 28th August 2009 06:22 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
