Acoustic Horn Design - The Practical Way
Old 10th June 2020, 08:36 PM   #41
danibosn is offline danibosn  Croatia
that was fast, thank you
Old 16th July 2020, 05:34 AM   #42
mabat is offline mabat  Czech Republic
mabat's Avatar
To those experienced with 3D printing, would you find it feasible to print a shell of a waveguide mould from several parts glued together? My idea would be to print a central part around the throat and several pieces around that. Even a small printer could be capable to print quite large moulds this way. I would generate STLs of the individual parts right from the program. This would be just the shell to get the shape, the interior would need to be filled.
www.at-horns.eu
Old 16th July 2020, 10:05 AM   #43
Imbecillen is offline Imbecillen
This is absolutely possible and roughly my idea as well. But I was thinking of doing an "inverted" 3D model as a mold that I print, to build upon with glassfiber and polyester or something like that. 3D printing is fine for smaller pieces but to glue bigger pieces together and then use it as a final horn can be tricky if not sanded and finished off with some filling and paint. Hope I understood and answered your question. Just tell me otherwise
With some trial n error, a good printer and some time on your hands you could definitely print a complete horn. Either in parts or as a whole with a bigger printer. Worth checking out prices if other print for you, isn't always that expensive. Also check with your local Makerspace (if there's any in your town) if you can use their printers if you want to try yourself.
Old 16th July 2020, 10:19 AM   #44
mabat's Avatar
Yes, this is precisely what I meant. I would like to try an "acrylic resin" - AcrylicOne.
I actually want to buy a (small) printer so there will be space for experiments. Thanks!
www.at-horns.eu
Old 16th July 2020, 11:58 AM   #45
diyiggy is offline diyiggy
diyiggy's Avatar
Please take care of you guys with organic volatile compound by using the appropriate grade protection mask... it's not because it's water solvant that this is not dangerous for health.
Old 17th July 2020, 01:08 PM   #46
pelanj is online now pelanj  Czech Republic
I wanted to do something similar - not a mould but a full horn from pieces. I volunteer as the printer. If PLA is enough, I can print the parts for you to try out. My smaller printer is 180x180x180 mm and the larger is 260 diameter x 350 mm delta style.
Edit: I already printed a few things in parts - if proper orientation is possible, it is not a problem - best if no supports were needed.
Old 31st July 2020, 12:34 PM   #47
mabat's Avatar
In the meantime we are progressing on Tritonia baffles (milled from a solid MDF block) -
www.at-horns.eu
Old 31st July 2020, 12:55 PM   #48
mabat's Avatar
Some of the drivers which I'm going to make waveguides for in the near future -
(BMS 4554, 18Sound ND4015Ti2, Faital HF1440)
www.at-horns.eu
Old 31st July 2020, 12:59 PM   #49
Wow, looks amazing!
Old 31st July 2020, 01:00 PM   #50
mabat's Avatar
BTW, have you seen the new JBL 4349?
www.at-horns.eu
Acoustic Horn Design - The Practical WayHide this!Advertise here!
Acoustic Horn Design The Easy Way (Ath4) mabat Multi-Way 2886 Today 09:02 AM
Acoustic horn virious Multi-Way 13 10th August 2016 02:52 AM
Practical MOSFET Amp Design/Speculation/Questions: Dura Solid State 2 16th October 2012 10:52 PM
Electrostatic design - is a round design practical? sashua Planars & Exotics 39 4th August 2005 04:30 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
