Acoustic Horn Design - The Practical Way
Thread Tools
Old 3rd December 2020, 04:58 PM   #111
pelanj is offline pelanj  Czech Republic
I found out that my printer should be able (in theory) to print the same waveguide if was scaled up to 400 mm overall diameter (from 260 mm). It would be printed in around 25 h and use a little above 1 kg of PETG filament. That makes me think about buying some 1.4" drivers
Old 3rd December 2020, 08:19 PM   #112
mabat is offline mabat  Czech Republic
mabat's Avatar
Sure, you could do that. As a result everything would just shift on the frequency axis to the left in the same ratio as the sizes. In this case it would be the ratio 1.4 - what was at 1400 Hz before will be at 1000 Hz now. This would hold for all the variables - the DI, HOM cut-ons or radiation impedance.
https://at-horns.eu
Old 4th December 2020, 06:47 AM   #113
Rxdroid is offline Rxdroid  Spain
Originally Posted by Patrick Bateman View Post
Keep in mind that you have to redesign the crossover, now that you're using a waveguide. The 'stock' Linn crossover will no longer be correct.
Or at the very least, measure the speaker and then use an equalizer to fix the response.
Thanks for the note, I have a speaker with a horn and another without, I'll take the measurements, interesting
thanks
Un saludo
Old 22nd December 2020, 08:37 PM   #114
Today I finally managed to measure the waveguide with DE500. I would say this is impressive.
Old 22nd December 2020, 09:04 PM   #115
atico5007 is offline atico5007  Argentina
Oh! F*ck! That is impressive indeed!
Old 26th December 2020, 02:18 AM   #116
grindstone is offline grindstone  United States
grindstone's Avatar
What he said...nice work!
Old 26th December 2020, 03:49 AM   #117
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
I believe these are pics of the waveguide, from here: Acoustic Horn Design - The Practical Way
Old 26th December 2020, 10:13 AM   #118
mabat's Avatar
Thanks. Here is a comparison with DE502 in "the same" waveguide:
Acoustic Horn Design - The Practical Way-de500-vs-de502-png
https://at-horns.eu
Old 9th February 2021, 05:50 AM   #119
WT is offline WT
I print ST260 waveguide and this is my measurement with Denovo audio DNA360 compression driver.
File Type: jpg 146170152_454064659052884_3196160463390514762_n.jpg (161.3 KB, 151 views)
Old 9th February 2021, 06:24 AM   #120
mabat's Avatar
Thanks! The print quality is awesome but the results are suspiciously bad.
Is this anechoic? Looks strange. I'm quite sure there's still something wrong somewhere else then with the WG or the driver itself.
https://at-horns.eu
Acoustic Horn Design - The Practical WayHide this!Advertise here!
Thread Tools
Acoustic Horn Design The Easy Way (Ath4) mabat Multi-Way 7170 Today 05:17 AM
Acoustic horn virious Multi-Way 13 10th August 2016 02:52 AM
Practical MOSFET Amp Design/Speculation/Questions: Dura Solid State 2 16th October 2012 10:52 PM
Electrostatic design - is a round design practical? sashua Planars & Exotics 39 4th August 2005 04:30 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
