Thermistor removal from crossover rebuild?
Old 15th May 2020, 02:39 PM   #11
Galu is offline Galu  Scotland
For those interested in the use of PTC resistors (polyswitches) for loudspeaker overload protection, there's a handy calculator on this site:
Loudspeaker Protection Components
Old 15th May 2020, 02:57 PM   #12
AllenB is offline AllenB  Australia
AllenB's Avatar
This has made me curious as well. IIRC polyswitches change state when 'triggered' then reconstitute. There has been uncertainty around them always coming back to the same low resistance.
Additionally the PTC could cause a varying small change in response along with changes in resistance. I don't recall what the thermal inertia is like but if it is slow it stands to reason it could also cause compression, and if fast, harmonic distortion.
Old 16th May 2020, 04:44 AM   #13
CliffR52 is offline CliffR52  Australia
CliffR52's Avatar
Originally Posted by Galu View Post
As JonSnell explains, this is a 'Positec' overload protection device. I discussed such devices with you in relation to your Mordaunt Short speakers. Sometimes their operation can become erratic with age. Provided you are not going to be turning the volume up beyond what is tolerable, you can short out the Positec by soldering a short length of copper wire across it.
Thanks G.
The overload aspect isn't a worry to me.
I never run Amps to crazy volumes and rarely exceed 50% on the volume control, so clipping or power damage shouldn't be an issue.
My concern was Jon Snells comment:
"it warms up, as it warms up the resistance increases and reduces the power to the tweeter.
This is a feature used on drivers to reduce the failure rate of overloaded speech coils and to make the sound more pleasing to the ear.
Removal will make the tweeter respond as though it is not working
I wouldn't want their removal altering the sound.
Old 16th May 2020, 04:52 AM   #14
Topping is offline Topping  United States
Without reading the whole post , the common knowledge. Is remove thermister , if you dont have RUGRATS around to blow up your tweeters. hhhhhaaaahhhhhhaaaaaaa
Old 16th May 2020, 08:31 AM   #15
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Is that 'the royal we'?
By we, I mean the PA industry.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 16th May 2020, 10:15 AM   #16
Sorry Jon, I understood that on re-reading your post.
Thanks for taking my remark in good humour.
Old 16th May 2020, 10:34 AM   #17
If I may be so bold as to speak for Jon, then by 'more pleasing to the ear' I think he means 'compressed'. Compression is not desirable, but during an overload it is preferable to a distorted then ruined tweeter.
By 'Removal will make the tweeter respond as though it is not working', I think he is stressing that if you simply remove the polyswitch, you will break the circuit path and the tweeter will stop working. That is why I tell you to replace the polyswitch with a short length of wire.
Old 16th May 2020, 11:01 AM   #18
Originally Posted by audiotechnica View Post
The parallel resistor is to allow continued and attenuated but not muted operation of the mid/highs during overload condition, ie idiot proofing.
Thanks for clarifying that. You appear to have interpreted Cliff's circuit description correctly.
@Cliff - Given audiotechnica's explanation, you may be advised to leave the protection circuit (the parallel combination of resistor and polyswitch) alone unless it is compromising the sound of the speaker. Failing that, it would have to be shorted out with a wire link.
If you can supply a crossover schematic then that would be helpful.
Old 16th May 2020, 11:17 AM   #19
For those interested in how polymeric positive temperature coefficient (PPTC) devices work, look here: Resettable fuse - Wikipedia
The article seems to suggest that allowing a polyswitch to operate frequently under overload conditions may lead to it no longer returning to its low resistance state and instead stabilising at a significantly higher resistance.
Old 16th May 2020, 11:24 AM   #20
turk 182 is offline turk 182  Canada
if the polyswitch is considered dubious why not consider a lamp limiter to protect the tweeter?
Thermistor removal from crossover rebuild?Hide this!Advertise here!
Simple 2-way Crossover Rebuild... Help Please? SONDEKNZ Multi-Way 25 6th April 2019 03:01 AM
Crossover rebuild questions Dinolobe Multi-Way 15 3rd March 2019 04:49 PM
Kef Concerto Crossover Rebuild TechnoDweeb Multi-Way 23 16th November 2017 11:57 AM
Crossover Rebuild Advise BlindMelon7 Analog Line Level 8 26th August 2016 09:09 AM
Jensen SS-100 crossover rebuild help cygnus x1 Multi-Way 6 15th June 2013 12:53 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
