Thermistor removal from crossover rebuild?
Old 23rd May 2020, 07:34 AM   #91
CliffR52 is offline CliffR52  Australia
CliffR52's Avatar
Originally Posted by AllenB View Post
With much added resistance the effect can vary with frequency where the impedance also varies. One way to reduce this effect is to attenuate using both series and parallel resistance.
That's very interesting.
So to overcome brightness or overly loud highs/mids would I add a resistor in series and listen for changes, but if brightness continues at given frequencies, add a similar value resistor in parallel.
Is that what you're instructing?
What ohm values would you incrementally try when doing adjustments?
thanks
Cliff
Old 23rd May 2020, 08:49 AM   #92
AllenB is offline AllenB  Australia
AllenB's Avatar
Say you have an 8 ohm resistor in parallel with a speaker which is (nominally) 8 ohms as well. That's four ohms total. Put a four ohm resistor in series to make a total of 8 ohms again. Now the signal Voltage is divided and the speaker gets half.
From here if you reduce the series resistance you should increase the parallel resistance and vice versa to maintain a balance of 8 ohms (not that you must stay at 8 ohms, but it keeps the crossover frequency).
Thermistor removal from crossover rebuild?Hide this!Advertise here!
Simple 2-way Crossover Rebuild... Help Please? SONDEKNZ Multi-Way 25 6th April 2019 03:01 AM
Crossover rebuild questions Dinolobe Multi-Way 15 3rd March 2019 04:49 PM
Kef Concerto Crossover Rebuild TechnoDweeb Multi-Way 23 16th November 2017 11:57 AM
Crossover Rebuild Advise BlindMelon7 Analog Line Level 8 26th August 2016 09:09 AM
Jensen SS-100 crossover rebuild help cygnus x1 Multi-Way 6 15th June 2013 12:53 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
