Hello @hifijim,
Looking through a couple of your threads I see that you are using the same woofer build in a couple of projects, SB34NRX75-6, plus sealed enclosure.
If you would I would like to read more about your selection of the driver, the dimensions; height width depth and volume of the enclosure, equalization and performance measurements.
Thanks DT
Thanks DT
