Exploring Purifi Woofer Speaker Builds
Old 22nd May 2020, 09:28 AM   #181
fedde is offline fedde  Netherlands
Originally Posted by xrk971 View Post
This driver makes a nice midrange but it was designed to be able to move a lot of air in a vented alignment. It would be a waste to use it on an OB. You couild use so many other drivers there as a midrange. Try Faital 6FE100 or 5MR450NDY. They have higher Qts and are also low distortion, and higher sensitivity.
A waste due to the relatively high cost for the performance, or because it would operate suboptimally?
The benefit of Purifi could be that a very low crossover could be used in OB, e.g. 100-200 Hz, maybe with a pair. And still it could go up to 2k or 3k, with very low IMD and THD.
I looked up the drivers you suggested, but they look not particularly special (though your response is appreciated!). As James, I am looking for a very high performing mid: very fast (to integrate with Heil AMT), wide bandwidth (to be flexible with crossovers and have low crossover to 15" woofer), very low IMD and THD. And useable in open baffle, so high xmax, higher Qts nice to have.
My short list so far is Purifi, Satori MW16 or MR16, and maybe some 8" wide banders. I already have a Supravox 215 Bicone which I will try out, but I expect its distortion and breakup will be much worse than Purifi...
Fedde
http://www.fedde.nu, gainclone, non-oversampling DAC and open baffle audio projects...
Old 22nd May 2020, 09:28 AM   #182
TNT is offline TNT  Sweden
Well, if you have EQ available you can choose any Qts bass unit. The high(er) Q need for OB is when one want decent output in the bass without EQ. But using a driver with a Q>0,5 is really to rely on resonance and that I would avoid really. This high Q bass driver in OB is a grand-paa problem - nowadays we do Q 0,5 with low reach using LT transform in DSP... good luck! (But 6" wont cut it in the bass of course!)
Originally Posted by jamesblonde View Post
Thanks for the suggestions and I agree that the Purifi's Qts of 0.32 is not optimal for OB.
I find it difficult to get hold of CSD and HD info on drivers so that eliminates the vast majority of drivers, unfortunately, but without being able to hear drivers beforehand this is all I have to go on.
I did find some distortion plots for the Faital but it doesn't seem to be in the same class as the Purifi with H2 and H3 HD hovering around -30 to -40dB. (Purifi is -60 to -70 dB).
Both drivers you suggested seem to have a linear Xmax of around 3mm compared with the Purifi's 10mm. The extra Xmax should give me some extra crossover flexibility, so that's another plus for the Purifi.
I'm also not concerned with high sensitivity as I will have 250W available for the midrange from the Hypex FA253.
More distortion to the people!
Old 22nd May 2020, 11:46 AM   #183
hallcon83 is offline hallcon83  United States
hallcon83's Avatar
- I think that It would be worth a try at least putting in an Open Baffle, yes you loose the great bass, but with orders of magnitude less distortion it also might be something special in an Open Baffle too - couldn't hurt to try.........
Old 22nd May 2020, 01:04 PM   #184
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
It will sound great - I was speaking from standpoint of cost effectiveness. In OB, you could probably take it down to 200Hz, but the sensitivity due to OB falloff is probably at least 6dB so it’s going to need EQ and it’s long stroke to compensate. Give it a try if the cost doesn’t bother you. Satori might work too but then you have the breakup on top to deal with.
I have tried the 5MR450NDY in OB and it sounds special. It is very low distortion as the sensitivity is so high, it doesn’t move very much. I crossed at 340Hz and had a slot loaded OB (SLOB) w 6x 6.5in woofers for the bass.
Cheap and FAST OB, Literally
This response was achieved with no EQ or BSC, just the crossover filter and level matching. Lucky indeed. It sounded very very good - I made a note to myself that one day when I have access to a wood shop I would recreate it in plywood as it was only made of cardboard.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 22nd May 2020, 09:19 PM   #185
It will sound great - I was speaking from standpoint of cost effectiveness. In OB, you could probably take it down to 200Hz, but the sensitivity due to OB falloff is probably at least 6dB so itís going to need EQ and itís long stroke to compensate. Give it a try if the cost doesnít bother you. Satori might work too but then you have the breakup on top to deal with.
I have tried the 5MR450NDY in OB and it sounds special. It is very low distortion as the sensitivity is so high, it doesnít move very much. I crossed at 340Hz and had a slot loaded OB (SLOB) w 6x 6.5in woofers for the bass.
Indeed, the response looks very good for a two way without EQ!
I look forward to the 8" Purifi. This would probably be a more cost effective option for open baffle as two units could be enough for deep bass. And efficiency will probably be higher. But it let's first see when this becomes available and what the price is...
Fedde
Old 23rd May 2020, 06:48 AM   #186
jasdiy is offline jasdiy  New Zealand
Fedde
Hell after success of the 6.5 I look forward to any drive they bring out " ill take 4 10s and a couple of 4, don't bother wrapping them" 😁😁
Old 23rd May 2020, 07:43 AM   #187
mainframe99 is offline mainframe99
With the bass you can get from this 6.5 the 8 should be awesome lets hope they pull it off!
Old 23rd May 2020, 08:32 AM   #188
Got Foam?
xrk971's Avatar
I am more impressed by the clear and clean midrange that the 6.5 makes. It is world class midrange like a nice fabric dome but with chest punch.
Old 23rd May 2020, 05:23 PM   #189
Why not wait till they make a 15" or 18"...
Old 23rd May 2020, 07:08 PM   #190
Norman Tracy is offline Norman Tracy  United States
Absolutely 100% agree. A good $400 15" woofer in a 5 cubic foot box or a 5 foot tall line array of GR Research servo woofers will deliver bass comparable to PURIFI's. It's the mid range clarity obtained by going after the previously unrecognized hysteresis distortion that is the currently unique benefit I hear from PTT6.5.
Norman Tracy
Audio Crafters Guild
Exploring Purifi Woofer Speaker BuildsHide this!Advertise here!
Purifi PTT6.5W04-01A woofer group buy CANADA sperrey Group Buys 0 25th February 2020 02:15 AM
Clearing out DIY speaker builds pjblakey Swap Meet 0 4th July 2013 04:07 PM
Do you use BSC on desktop speaker builds? mayhem13 Multi-Way 3 4th April 2013 11:46 PM
Where to start with DIY speaker builds? Kooshball Multi-Way 50 27th August 2012 10:41 AM
My first speaker builds - Thanks for the help stuartdj_x Multi-Way 13 19th October 2005 01:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
