synergy.....Take #7
synergy.....Take #7
Old 26th March 2020, 06:14 AM   #11
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
synergy.....Take #7
Mark100, I didn't do as thorough testing as you did, but in what I did test I also never saw much benefit from putting the taps in the corners -- the closer I got to the corners, the more issues I seemed to have. And getting the tap in the center of the midrange/midwoofer driver does wonders for the high end of the midrange driver if you can get it there. Skootching the upper corner of the midrange was always the battle in the syns I did. Getting that tweeter crossover point down lower is probably the best (though expensive) way to go. I'll be interested to see what people can do with that new Eminence compression driver.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 26th March 2020, 06:18 AM   #12
bwaslo's Avatar
synergy.....Take #7
Originally Posted by jjasniew View Post
Why not 3D print the throat part, and mount it as a component to the wood part? That would make the critical small dimensions consistent and easier to realize.
http://libinst.com/SynergyDIY/StubV6...me%20plugs.stl
Old 26th March 2020, 02:53 PM   #13
mark100 is offline mark100  United States
synergy.....Take #7
Originally Posted by fluid View Post
Hiding the ports in the corners and making them smaller had effects on the tweeters output, in that that when the ports are closer for midrange drivers the effects are greater. When you move them out further they have less effect. Pushing the tweeter lower like with your DCX makes a lot of the other compromises less important.
The depth, frustrumming and needing to use a cone plug comes down to trying to push the midrange low pass frequency higher. Horn resp sims shows the interaction of the volume of air in the throat chamber, port length and size. When you move the target down to 500Hz that is easier too. The 10FE200 also has a pretty shallow cone and not that much trapped air, a deeper cone might well present differently.
Centering the port over the driver will minimize path length differences and seems like a no brainer but it is not always possible when trying to juggle the physical size of midranges close enough to the throat.
Yep, what you and Patrick are saying about closer to throat having more potential negative impact, has been my understanding too.
If I were using a smaller 4-5" mid to bridge higher, I'd be very curious to try their ports out of the corners too....just to know...
The 10FE200 has been pleasant surprise, in how well it fit the design goal of low weight, and then how well the port size /location kinda fell into place.
I might end up reducing volume under the cone to try to raise response above 500Hz a bit more. But maybe not, it's sounding awfully good as is
Below is the mid raw response.
Oh, one test I just ran indoors, was a 1m sensitivity test on the processed mids, as the 10FE200's are clearly what will run out of steam first. (xovers at 100 and 500Hz)
The two 4 ohm drivers in series, give 102.5dB at 2.83V.
That calculates to about 127dB at AES wattage rating.
Not bad for a 45 lb box
Mark be happy camper !
Old 26th March 2020, 03:03 PM   #14
synergy.....Take #7
I thought I had remembered you saying ports out of the corners had worked for you. Thanks for replying with your experiences.
And yep, getting the port under the center on the cone, moved freq response up enough I haven't felt the need to reduce volume under the cone.
I'm very interested to see how the new Eminence works, too.
If CDs become better priced and can reach down into the dcx and bms low corner freq range, it seems like we will see a lot more builds skipping the smaller bridging mids.
Old 26th March 2020, 04:00 PM   #15
jjasniew is offline jjasniew  United States
jjasniew's Avatar
your pix
Well, that's exactly what I had imagined!
Joe Jasniewski - PC>ZOUDIO AIO4CH> OB Lii Audio F15s w/ 18" assists.
Old 26th March 2020, 04:59 PM   #16
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
synergy.....Take #7
Nice work Mark100! I also had a similar experience with making the crossover at 600Hz. I used a Heil AMT which let me go low. The mid range was easy to mount on the top panel. I used two hot dog shaped slots but probably a round would have worked too. The low XO is key to a an easy to make and simple Synergy. Basically following the FAST recipe for a low frequency crossover 2-way.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 26th March 2020, 09:18 PM   #17
nc535 is offline nc535
Is that the reflection (from the throat/CD) null at around 630 Hz? Maybe you could kill it with mid impulse response inversion. It would be an interesting experiment...
My Synergy Corner Horns and Bass Bins
http://www.diyaudio.com/forums/multi...bass-bins.html
Old 26th March 2020, 10:50 PM   #18
fluid is offline fluid  Australia
Seems low for the tweeter throat but it does look a reflection null of some kind.
Old 26th March 2020, 10:55 PM   #19
synergy.....Take #7
Thx xrk971 !
Interesting you played with hotdog shapes too ... i wanted to try such, but ran out of experimenting willpower/patience lol..
So the Heil is good to 600Hz? That's really cool and very enticing...
Old 26th March 2020, 11:00 PM   #20
synergy.....Take #7
I think probably so.
Mid inverse would be very interesting.
If i decide i need to push mid-to-high xover freq above 500Hz, I'll give this a try.
synergy.....Take #7Hide this!Advertise here!
Synergy DIY ellisr63 Multi-Way 62 19th May 2020 07:39 PM
REW tweaking of synergy Droco Software Tools 0 22nd March 2020 11:53 AM
Two Way Synergy??? Patrick Bateman Multi-Way 28 2nd December 2019 11:47 PM
Klipsch synergy sub-10 skwrangler Subwoofers 1 5th March 2014 04:24 PM
Synergy dipole ? bzfcocon Multi-Way 12 24th November 2013 09:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
