Small Speakers using Infinity CMMD Drivers
Old 26th March 2020, 04:55 PM   #11
BradH is offline BradH
I'll have to get one more driver for the center, or just TMW center identical to the rest, mounted upside down and angled toward listener.
What kind of measurements would I need to take in order to ask for help on a TMW crossover? Just a freq. sweep? Do multiple polars help?
Old 26th March 2020, 11:52 PM   #12
I have a lead on qty(8) 5-1/4" CMMD drivers from a different line for less than $200. Of course no measurements but should I go for it anyway? Then each speaker has one 4" mid and one 5-1/4" woofer to get down to the subs? Center can have one 4" and two 5-1/4". I know this is a bit of a janky build but we can have some fun with it no?
Old 27th March 2020, 12:48 PM   #13
454Casull is offline 454Casull  Canada
Originally Posted by planet10 View Post
That works because you can get the W to M XO within that 1/4 wavelength metric.
dave
Its possible, but usually rather difficult. Typically youd end up with a sub-2 kHz crossover to a 3 mid and perhaps even need to use a small-format tweeter.
Old 27th March 2020, 03:42 PM   #14
Is freq response enough to see if two drivers match up? I'm thinking of buying these 5.25" drivers. They are from the second iteration of the Primus line, mine were from an earlier line, the Modulus and the Entra. I'd be looking to have the 5.25" do a narrow range from about 300 down to subs. Or should I just stick with two 4"? Worried about the midbass band being weak vs complexity of trying to integrate different drivers with unknown t/s.
Old 27th March 2020, 11:28 PM   #15
Picked up eight 5.25" drivers today for $150 CAD.
This is all the info I can really find on them until I take a look at the crossovers they came with.
Infinity 5.25"
Good news is that they are used in a center channel, the PC251 in sealed configuration. They claim to get down to 80hz in that small enclosure.
Old 27th March 2020, 11:45 PM   #16
Question: In the case of these modulus speakers, the 3/4" tweeter crosses over to the 4" mid at 2500 hz, which is 5.24". Since the woofer is not beaming at this point why does the tweeter use a waveguide that is 2.5" at the mouth? 2.5" = 5400 hz.
Small Speakers using Infinity CMMD DriversHide this!Advertise here!
Infinity midrange drivers, two marknoir Swap Meet 0 1st September 2019 01:59 PM
Infinity SM122 drivers for OB with CHP70? wendelltate Multi-Way 2 1st May 2014 10:10 AM
Thiele Small Parameters - Infinity Kappa Perfect gwolfman Multi-Way 8 28th April 2011 10:35 PM
FS: Infinity 6x9, 2 way car speakers Stuart Easson Swap Meet 0 8th August 2006 01:06 AM
Drivers - Infinity, MB Quart or what? MikeFarad Car Audio 3 23rd March 2004 09:39 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
