Working the crossover for better impedance
Old 29th March 2020, 12:23 AM   #101
Douglas Blake is offline Douglas Blake  Canada
Douglas Blake's Avatar
Originally Posted by Kustomize123 View Post
When you mentioned Audyssey , I decided to give it another try.
So, did you actually follow any of my recommendations?
Old 29th March 2020, 12:43 AM   #102
Kustomize123 is offline Kustomize123
I did but itís not working for my fronts due to space constraint.
My room has no space from either sides of my fronts. They can be pulled CLOSER together, but not farther.
That would be less ideal, no? Because theyíre already only 6 feet apart, and my Listening position is at 10 ft. The max I can do is push them back towards the walls abit. I did move the subwoofer a little bit out of the corner, and into the room diagonally.
Also, I think the dips might be my room reflections, as itís not treated at all. Bare walls, and no carpeting, marble flooring. Have some furniture and TV around snd curtains, and thatís it. Basic.
Old 29th March 2020, 12:53 AM   #103
I did but it’s not working for my fronts due to space constraint.
Okay ... well, there isn't much I can do to help you if you're not going to follow my advice... Good luck with all this.
Old 29th March 2020, 01:32 AM   #104
Youíve helped a ton and I thank you for that! I am not disregarding your guidelines!
Maybe if you see this, you could better understand the space I am working with. Its very much far from ideal!
File Type: jpeg FEFEC379-54D8-4490-AC39-AC9D3317D971.jpeg (273.4 KB, 55 views)
Old 29th March 2020, 01:45 AM   #105
I think in your place, my first priority would be to rearrange the room.
Old Yesterday, 10:14 AM   #106
system7 is offline system7  United Kingdom
system7's Avatar
Kustomize123, if you still have this project on the back-burner, you may be interested in MIchael Chua's take on the drivers in the Zaph|Audio - ZA5 Speaker Designs with ZA14W08 woofer and Vifa DQ25SC16-04 tweeter, ZA5.3t.
Swift 2.5 (Zaph ZA14W08 with Peerless DQ25SC16-04) – AmpsLab
Mike feels the impedance is comfortable. And the tweeter can't be wildly different.
Worth an email for details and a bit of simming, I think. Not usually hard to redesign a tweeter filter for higher impedance either. Smaller cap, bigger coil and a resistor in front of the filter. Hope it helps.
Best Regards from Steve in Portsmouth, UK.
Working the crossover for better impedanceHide this!Advertise here!
Crossover Design: Low Impedance after 5k in the Impedance Curve ikidnextdoor Multi-Way 40 20th March 2020 06:24 AM
Working on some speakers - upgrade crossover? surfdabbler Multi-Way 4 10th September 2019 05:26 AM
Please help passive crossover not working. awdtalon21 Multi-Way 4 1st July 2017 05:02 PM
Which Impedance for Crossover Calculation? The Nominal, the One at Crossover or? T101 Multi-Way 23 10th October 2013 02:10 AM
Working on crossover, wondered about something... BAM Multi-Way 10 20th April 2004 08:03 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
