Monacor ht 22 / Mark Audio CHP70.2
Old 24th March 2020, 09:23 PM   #31
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
...Harbeth use...
One of the ones i have has a custon PSB bezel.
Many others used it too.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th March 2020, 09:47 PM   #32
system7 is offline system7  United Kingdom
system7's Avatar
Been there, worn the T-Shirt. Washed it, Ironed it! Put new ferrofluid in it....
H0532-08 19TAFD/G
Have sent His Chuaness an email. Await further developments. I'm not going anywhere. His Borisness has ordered me to stay at home via Text Message.
Best Regards from Steve in Portsmouth, UK.
Old 25th March 2020, 04:49 PM   #33
sk971 is offline sk971  United Kingdom
A text from our Great Leader ��
I look forward to hearing any further information. I took a good look at Ampslab and he definitely has done a lot with the chp70 so hopefully some ideas .
Cheers Simon
Old 25th March 2020, 04:51 PM   #34
system7's Avatar
MIchael Chua, what a gent, got back to me with some helpful data. He's busy amplifiering at the moment, so can't look in.
Anyhoo, it's all simple enough and doable.
And I do think the Visaton SC5 tweeter will just slot in.
He is planning a bigger version himself, using a simple bit of bafflestep.
The simple circuit is just 5 components. The bafflestep version an extra 4, but reusing the other 5.
I'd go for it, Simon.
Old 25th March 2020, 05:23 PM   #35
Sound great Steve !
Old 25th March 2020, 05:38 PM   #36
system7's Avatar
Loudspeaker Projects – Passive, Active & Time Aligned – AmpsLab
I seem to remember that B&Q will cut sheet of timber to size for nothing. 10 cuts free or something.
You might scout out Wilmslow and Impact for most of the bits:
Speaker Repair, Speaker Kits, Loudspeaker Repair, Kits and Drive Units, Subwoofer Amplifier Kit
Impact Audio - Visaton Loudspeakers, TEAC, Myryad & Roksan HiFi Sy
Both do generic circuit boards.
Soldering Irons at Screwfix, IIRC.
Seems to me you could do all sorts of things from a simple 10L reflex box to a FrugelHorn III:
Fullrange speaker kits | KJF Audio
From what I've seen, it will work just as a fullranger to get you started. But does fall away at 5kHz.
Monacor ht 22 / Mark Audio CHP70.2Hide this!Advertise here!
Some nice speakers. Audio Tech C-Quenz, Mark Audio, Peerless vactor Swap Meet 32 8th March 2014 02:40 PM
Mark Audio Mark-Ten or Holly65 with the Gardient AXT-08 Ronald67 Full Range 4 11th January 2014 08:01 AM
Mark Audio CHP70 Waves73 Full Range 20 23rd January 2013 09:01 PM
Mark Audio CHP70 Vs. Tang Band W3-871 Tyimo Full Range 9 5th April 2011 10:25 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
