Mid-dome directivity mismatch? (Vituixcad simulation)
Old 24th March 2020, 07:21 AM   #21
Boden is online now Boden  Netherlands
@ Juhazi: OK now I understand, you meant off axis. In my book driver offset ususally refers to the Z axis of the drivers. Thanx.
Old 25th March 2020, 01:09 AM   #22
DonVK is offline DonVK  Canada
DonVK's Avatar
@Arnandsway : The H-polars should be very wide given the driver size and XO points.
I have not used VituixCad but I can offer some things to try to isolate the cause. Have you tried driving the woofer then midrange each individually to see if you get the polar responses you expect. It should be 120-180deg (at mid driver height) given the driver size and XO points. I can't tell from the graphs because I don't know the conditions (heights, distance, etc).
Have you tried the FRD / ZMA data that Dayton supplies. They are usually pretty good with their data. The data from @HiFiCompass is also an excellent source, but it seems you needed additional step(s) to extract data from the curves.
The other place to ask is in VituixCAD where the S/W author (@Kimmosto) answers tool specific questions.
Mid-dome directivity mismatch? (Vituixcad simulation)Hide this!Advertise here!
VituixCAD diypass Software Tools 1881 Yesterday 05:02 PM
What is SPL high and low impedance VituixCAD FriedMule Software Tools 43 12th January 2020 12:38 PM
Vituixcad phase and gd screen fjadouce100 Multi-Way 10 1st October 2019 12:25 PM
Help, can I use VituixCAD to merge simulated driver measurements Jeremy067390 Software Tools 5 4th January 2018 04:10 AM
A question about directivity in Boxsim simulation andreaemme Multi-Way 49 20th June 2016 06:24 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
