Please review my plans to recap Polk Monitor 5s
Please review my plans to recap Polk Monitor 5s Please consider donating to help us continue to serve you.
Old 7th February 2020, 01:52 AM   #1
KenAnderson is offline KenAnderson  Canada
Default Please review my plans to recap Polk Monitor 5s
Hi all.
I obtained my Monitor 5s free a couple of months ago, and they don't sound as good as I'd like, so it's recap time. I've already replaced the external fuses, and that helped big time.
I have no soldering experience, and nowhere near the electronics knowledge that I'd like to have, but this really doesn't look too hard. To practise my soldering skills, I unsoldered tiny resistors and caps in a radio I picked up at the dump, and then soldered them back in. I'm feeling confident about being able to do the larger components that I think I need for this project.
I've read a bunch of posts in this forum, and think I know what I need to do, but I'd really appreciate it if one or more of you would just have a look at my plans and let me know if I'm good to go, or if I need to make changes, or if you think I should choose other parts.
I've attached a pic of the crossover below.
As near as I can tell, I have the following parts.
  • 12uf at 50vac electrolytic capacitor
  • 34uf at 50vac electrolytic capacitor
  • 6.2 ohm resistor at 5w
  • 2.7 ohm resistor at 5w
I plan to replace these with one of the following configurations. One config is considerably more expensive than the other.
Expensive
  • Sonicraft GEN I 12uf Capacitor, from Sonic Craft, 28.46 USD each
  • Sonicap Gen I 34 uF 200VDC, rom Sonic Craft, 62.01 USD each
  • Mills Resistor 6.2 ohm 5 watt MRA-5, from Sonic Craft, 4.60 USD each
  • Vishay Mills Resistor 2.7 ohm 5 watt MRA-5, from Sonic Craft, 3.95 USD each
Sonic Craft shipping 24.12 USD
Total price for two of each component plus shipping to Victoria, B.C., 295.47 CAD!
Cheaper
  • Clarity PX 12uF 250VDC, from Meniscus, 9.40 USD each
  • Jantzen Audio 33uF 400V Crosscap Capacitor, from Parts Express, 13.54 USD each
Meniscus shipping 12.25 USD
Parts Express shipping 31.31 USD
Sonic Craft shipping 14.93 USD
Sonic Craft handling 10.00 USD
Total price for two of each component plus shipping and handling to Victoria, B.C., 174.06 CAD.
I think I'll go the cheaper route, and save myself $125 CAD.
I understand that I should also get replacement standoffs, in case the existing ones don't survive my work. Where do I go to get these?
And, lastly, the existing caps are rated at 50VAC. Replacements are VDC caps. Will that cause me any problems? If "yes", what do I do to deal with those problems?
Thanks,
-Ken
Old 7th February 2020, 01:56 AM   #2
rayma is offline rayma  United States
No problem with the voltage ratings. Sure the new caps and resistors will fit?
For similar standoffs, look for Panduit in Digikey, Mouser, etc.
Old 7th February 2020, 02:10 AM   #3
Inductor is offline Inductor  Portugal
Inductor's Avatar
Caps: Vac and Vdc is (almost) the same thing except, for the same cap "Vac" is higher because it doesn't heat up so much the capacitor.
#Barry&Friends/Dj''S''Soul-Mix
Old 7th February 2020, 08:59 AM   #4
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Lightbulb You can do better if you look long enough!
Because the order is still below minimum amount, you have all sorts of gadgets to choose from to modify speakers even further, and you could exchange the inductors as well.
Old 13th February 2020, 07:57 PM   #5
tuantran is offline tuantran  Canada
tuantran's Avatar
PCX INDEX
Hi KenAnderson, please check partsconnexion in Toronto to see if you can find any good component. Cheers!
Old 13th February 2020, 08:55 PM   #6
PeteMcK is offline PeteMcK
no need to replace the resistors; the main difference between cheap and expensive caps is marketing...
"A Fenderr Telecasterr has mair penetration than an AK47" - Alex Harvey
Old 14th February 2020, 08:33 AM   #7
Lojzek's Avatar
Seems like OP does not appreciate that kind of comments. Perhaps this thread is all about marketing.
Old 14th February 2020, 03:35 PM   #8
tuantran's Avatar
when i see the photo i guess that the original capacitors are the film capacitors
Old 18th February 2020, 03:56 PM   #9
tuantran's Avatar
I have the list of components from Parts Connexion for upgrading the crossovers
Clarity Cap PX 12uF 250V 9.34 X 6 = 56.04 CAD
Clarity Cap PX 10uF 250V 8.06 x 2 = 16.12 CAD
Mills resistor 12W 6.2 Ohm 7.42 x 2 = 14.84 CAD
Mills resistor 12W 2.7 Ohm 7.42 x 2 = 14.84 CAD
Total is 101.84 CAD plus shipping and handling.
I don't have experience with Clarity Cap PX 250V but i have used Clacity Cap ESA 250V and i like it but ESA 250V capacitor is more expensive. Hope this will help to improve the sound of your speakers. Cheers!
Old 18th February 2020, 06:54 PM   #10
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Check the ESR of the big electrolytics before replacing.
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Please review my plans to recap Polk Monitor 5sHide this!Advertise here!
Need help with old Sony Sub and Polk Monitor 40s... stardust4ever Solid State 13 3rd May 2017 07:50 AM
Need HELP!!!! POLK AUDIO MONITOR 30 msj965 Multi-Way 5 26th February 2011 06:39 PM
plans for DIY Polk lsi9? bigbigN Multi-Way 2 21st July 2009 03:09 PM
New Polk Monitor 10 Configuration - HELP!!!! boonaroo Multi-Way 6 11th April 2009 03:00 AM
Polk Monitor 70 Speakers crippledchicken Multi-Way 1 20th February 2008 06:25 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
