Focal 826 Tweeter Removal
Old 14th April 2020, 04:56 PM   #151
Galu is offline Galu  Scotland
I agree with Douglas. There's no need to cut the cable to expose fresh copper.
I would add that you should keep your soldering iron in contact for as short a time as is possible.
Excess heat can damage delicate tweeter connections.
Old 15th April 2020, 09:38 PM   #152
Plx79 is offline Plx79
Actually looking at this picture it looks that there is a connector at the end of the tweeter cable.
https://i.ebayimg.com/images/g/Jd4AA...auX/s-l400.jpg
So, apparently, I will have to remove the mid-range first for reaching the connector on the crossover.
This for sure would be a more clean work than resoldering the cable, but it requires more effort on dismounting and remounting the speakers back.
Does anyone of you know if the screws that hold the speakers (the mid-range in my case) needs to be fastened back with a specific tightening torque like for a engine crankcase?
Old 15th April 2020, 09:58 PM   #153
Depends on whether your replacement tweeter comes pre-wired or not, but access to the crossover is indeed through the midrange aperture if required.
No specific torque. Use a hand screwdriver to nip up the screws sequentially, a little bit at a time, until resistance is felt. Do not force the screws beyond this point of resistance.
Old 30th June 2020, 10:10 PM   #154
manizkrishnan is offline manizkrishnan
Originally Posted by Plx79 View Post
Hello manizkrishnan,
Sorry to resume this thread but I'm in the same your condition.
I would like to know, once that you have extracted the tweeter, what do you need to do for actually replace it?
Do you need to unsolder the old one and resolder the new one, or is it just a matter of unplug/replug the contacts?
Thank you!
Sorry for the delay. No soldering is needed. It is just a clip which will attach to existing wires.let me know if you need any help.
Focal 826 Tweeter RemovalHide this!Advertise here!
Can anyone help me with this tweeter removal? Focal Chorus 836V PoorSound Multi-Way 8 29th February 2020 09:23 PM
B&W 801 S3 tweeter/midrange head removal tubularfluxus Multi-Way 6 9th May 2016 10:56 AM
Ribbon Tweeter Wave Guide removal? deanxxx Multi-Way 5 4th April 2012 05:14 PM
Tweeter diffuser removal recommendations? Eton Multi-Way 0 15th August 2005 01:47 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
