Kenwood 2-way crossover
Kenwood 2-way crossover Please consider donating to help us continue to serve you.
Old 29th January 2020, 11:22 AM   #41
giralfino is offline giralfino  Italy
giralfino's Avatar
The crossover is supposed to be at 6400 Hz (it is written on the speaker)
My questions are:
- Is the coil value 0.27mH?
- If i want to attenuate of 3 dB more the tweeter, what resistor should i use ? Lpad?
- the capacitor is a crappy bipolar, would it be beneficial to use a film here?
- same question with the coil, it is a low quality ferrite coil, would it be beneficial to use a air coil here?
Going back to the original question. It seems you have an old speaker with a very minimal crossover. Maybe you can obtain something better from this speaker redesigning the crossover but without measurements of the actual drivers nothing can be really achieved (IMHO).
What you really need to do is to replace the cap with a new one (same chemistry and value). Old electrolytic have capacitance far off and thus the crossover won't work as expected anymore.
We can't know what the coil value is, or it is written on it or should be measured, this isn't strictly a standard crossover (resistor place). Besides that changing a coil makes sense only when it is broken, but a coil hardly broke.
As far for the attenuation of the tweeter, the resistance needed depends on the actual impedance of the driver (not the nominal one). But changing the value of the resistor will wary the crossover point and also the FR (will change the slope), so if you want to attenuate further the tweeter (*) placing an l-pad after the crossover is the only sensible option.
Ralf
(*) How do you know you need a 3dB attenuation?
Old 30th January 2020, 03:44 AM   #42
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Great post, Ralf. Nobody here never raised rhe things you remarked
It's like learning sex during the Victorian era: you get to the wedding night and there are many things to do that you never imagined.
Kenwood 2-way crossoverHide this!Advertise here!
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux Tfive PC Based 602 Today 04:46 PM
Compatibility of Kenwood Speaker 140W 6 Ohms per channel and Kenwood Amplifier KA-V70 Dadz Solid State 2 31st August 2019 06:46 AM
Do i need analog active Crossover or Digital Crossover for DIY home theatre speakers? dipankar862 Multi-Way 43 16th March 2017 06:55 AM
Kenwood KEC-600 crossover mike49504 Car Audio 3 20th August 2011 10:26 PM
Kenwood KAC-1023 crossover/gain board, same as in other *23-series? gisewhcs Car Audio 9 25th January 2011 03:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
