Can compression drivers sound "high end" home fi ? Vortex 15 ?
Old Yesterday, 09:40 PM   #51
Brinkman is offline Brinkman  United States
I usually upgrade the crossover parts anyhow, such as swapping the iron core inductors with aircore, Mills resistors, film & foil tweeter caps, etc., so this is perfect for me.
Also (and I probably shouldn’t let this secret out): In my ordering experience, Erich’s opinion of what is b-stock is incredibly nitpicky and many vendors would disagree that it warranted a discount.
Also, you still get free shipping:
File Type: jpeg 5E0AF9C5-73E8-44CA-8CA1-C5F72E7E9D76.jpeg (55.9 KB, 71 views)
Old Yesterday, 10:40 PM   #52
Schmitz77 is offline Schmitz77  Germany
Do you really think that air core inductors better iron core inductors?
Asians have the opposite view.
Old Yesterday, 11:03 PM   #53
I don’t think there’s any question that if size cost and weight are not a factor and the DCRs are equal, then yes the air core inductor is technically superior to its iron core counterpart.
Subjectively I’ve never done a DBT so I wouldn’t proclaim air cores as definitively sounding superior but yes, in sighted A/B tests I did succumb to the suggestion that such is the case.
I personally would use them in *any* passive crossover where the driver in the network is being used below 80hz but would be much more conservative when consulting others (ie loudspeaker power demands).
Can compression drivers sound "high end" home fi ? Vortex 15 ?Hide this!Advertise here!
"cheap" compression drivers suitable for a classic 3-way horn system? freddi Multi-Way 8 2nd September 2018 09:28 PM
High performance 1" Compression drivers/waveguides for HiFi Loudspeaker Project darkmatter Multi-Way 1 13th January 2018 04:41 PM
1" compression drivers with 2" diaphragms 454Casull Multi-Way 24 9th August 2009 04:19 PM
Keele, D. (2004) "Maximum efficiency of compression drivers" svenr Multi-Way 3 28th October 2007 02:03 PM
Using "high-end" car subs for home? mazeroth Subwoofers 21 25th August 2004 01:39 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
